AXIS P1425-LE is a compact, outdoor-ready bullet-style camera with built-in IR. This day and night camera is ideal for continuous video surveillance, in exposed outdoor areas such as parking lots, service stations and for general indoor surveillance purposes where a compact camera is needed.
Excellent image quality
AXIS P1425-LE with varifocal, P-iris lens provides excellent image quality at 30 frames per second in 2MP / HDTV resolution. The P-iris control provides optimal depth of field, resolution, image contrast and clarity. The cost-effective, compactly designed camera offers multiple H.264 and Motion JPEG streams that can be individually optimized for bandwidth and storage efficiency. -
Built-in IR-LEDs and OptimizedIR
AXIS P1425-LE offers Axis OptimizedIR, a power-efficient LED technology that provides an adaptable angle of IR illumination and discreet integration of IR LEDs, the cameras provide automatic illumination of a scene in complete darkness, at an event or when requested by a user. The IR LED illumination, which is invisible to the human eye, is perfect for discovering objects in a range of up to 15 meters. -
Edge storage for reliable surveillance systems
AXIS P1425-LE offers support for edge storage that allows recording video directly to a storage such as a microSD/SDHC card, thereby creating a flexible and reliable video surveillance system. -
Ease of installation
AXIS P1425-LE has a compact low weight casing and integrated bracket for wall or ceiling mount. AXIS P1425-LE offers easy installation with remote zoom and focus for fine tuning of the picture from a computer as opposed to at the camera itself. Furthermore, the pixel counter assures that the required pixel resolution is met. In addition the camera supports corridor format which allows you to get a vertically oriented, "portrait"-shaped video stream for effective monitoring of narrow areas. Power over Ethernet supplies power to the cameras via the network, which eliminates the need for power cables and reducing installation costs. -
I/O ports
The input/output port can be used for simple notification to an alarm panel or control of a relay or similar. The input is also ideal, for instance, when using a PIR sensor.
- AXIS P1425-LE Network Camera - network surveillance camera
- Network surveillance camera - fixed - outdoor
- Camera Mount Type
- Wall mount
- 9 cm x 26 cm x 9 cm
- 788 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 3.5 x
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- CMOS - 1/2.8" - 2 MP
- Minimum Illumination
- 0.25 lux - colour - F1.4 , 0.05 lux - B&W - F1.4
- Focal Length Control
- Vari-focal
- Focal Length
- 3 mm - 10.5 mm
- Focus Adjustment
- Automatic
- Lens Iris
- F/1.6
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Exposure compensation, Backlight Compensation (BLC), sharpness control, white balance, colour control, brightness control, Wide Dynamic Range (WDR), Privacy Mask Function, digital PTZ function
- 3-year warranty
- Environmental Parameters (operating)
- -30 °C - 50 °C; 10 - 100% relative humidity
- Camera Mount Type
- Wall mount
- Wired
- 9 cm
- 26 cm
- 9 cm
- 788 g
Camera
- Colour - Day&Night - fixed - outdoor
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Exposure Range
- 1/37000 sec - 2 sec
- Video Capture
- 1920 x 1080 @ 30 fps
- RAM
- 256 MB
- Flash Memory
- 128 MB
Image Sensor
- 2 MP CMOS 1/2.8"
Lens Construction
- Vari-focal
- Optical Zoom
- 3.5 x
- Focal Length
- 3 mm - 10.5 mm
- Lens Iris
- F/1.6
- Focus Adjustment
- Automatic
- Horizontal Field of View (degree)
- 33 - 92
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, IGMP, QOS
- Alarm Inputs Qty
- 1
- Alarm Outputs Qty
- 1
- Included Accessories
- Mounting bracket, sunshield
- C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, IEC 60529 IP66, EN 61000-6-1, ICES-003 Class A, NEMA Type 4X, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 B Class A, VCCI Class A, KN24, AS/NZS CISPR 22, IEC 60950-22, EN 60950-22, UL 60950-22, KCC KN22 Class B
- Power Requirements
- PoE
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years
- -30 °C
- 50 °C
- Relative Humidity (operating)
- 10 - 100%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
