Axis OutDoor Ready IP66-Rated PTZ Dome Camera
Quicklinx: 6N38WS00 Mfr#: 0317-002
AXIS Q6032-E is an outdoor-ready PTZ dome network camera for cost-efficient and reliable installation in demanding surveillance applications. It is ideal for use at airports and seaports, as well as for city and perimeter surveillance. The camera is powered through high power over Ethernet. This simplifies installation since only one cable is needed.
Arctic temperature control allows the camera to not only function at -40°C but also power up at that temperature following a power failure. AXIS Q6032-E can operate in temperatures from -40°C to 50°C. It has an IP66-rated protection against dust and water.
AXIS Q6032-E has a fast and precise pan/tilt response. In addition, it can tilt 20° above the horizon for a total tilt range of 220°, enabling better views, especially over uneven terrain. It has 35x optical and 12x digital zoom. The camera has an auto-tracking functionality that can automatically detect and follow a moving object within the camera's field of view.
  • Demanding outdoor video surveillance
  • Reliable operation in extreme climates
  • Precise pan/tilt performance and high zoom
AXIS Q6032-E PTZ Dome Network Camera - network surveillance camera - dome
Network surveillance camera - fixed - dome - dustproof / waterproof
23.2 cm x 23.2 cm x 26.8 cm
3.5 kg
Wired
Camera
Colour - Day&Night - NTSC
Optical Zoom
35 x
Max Resolution
704 x 480
Optical Sensor Type
EXview HAD CCD - 1/4"
Focal Length
3.4 mm - 119 mm
Focus Adjustment
Automatic
Lens Iris
F/1.4-4.2
Panning Range (degree)
360
Tilting Range (degree)
220
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Motion sensor, sharpness control, colour control, alarm function, progressive scanning, adaptive lighting, image stabilizer, SD-card slot, brightness control, Power over Ethernet, contrast control, e-mail alerts, image flip
3-year warranty
Environmental Parameters (operating)
-40 °C - 50 °C; 0 - 93% relative humidity
Dome
Wired
23.2 cm
23.2 cm
26.8 cm
3.5 kg
Europe
Camera
Colour - Day&Night - fixed - dustproof / waterproof
Video Format
NTSC
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
704 x 480
Digital Zoom
12
Exposure Range
1/2 sec - 1/30000 sec
Video Capture
704 x 480 @ 30 fps , 176 x 120 @ 30 fps
RAM
128 MB
Flash Memory
128 MB
Image Sensor
EXview HAD CCD 1/4"
Lens Construction
Optical Zoom
35 x
Focal Length
3.4 mm - 119 mm
Lens Iris
F/1.4-4.2
Focus Adjustment
Automatic
Horizontal Field of View (degree)
1.7 - 55.8
Panning
Range (degree)
360
Speed (degree/sec)
Up to 450
Tilting
Range (degree)
220
Speed (degree/sec)
Up to 450
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, HTTP over SSL, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, UPnP, Bonjour, RTCP, IGMP
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
Clear and smoked domes, sunshield
UL, C-Tick, VCCI Class B ITE, cUL, EN 61000-3-2, GS, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, EN 60950-1
Power Requirements
PoE
Power injector - external
Software Included
Drivers & Utilities
Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Microsoft Windows Vista
Limited warranty - 3 years
-40 °C
50 °C
Relative Humidity (operating)
0 - 93%
