Axis M7014 Video Encoder - Video Server - 4 channels
Quicklinx: 8DWLWS00 Mfr#: 0415-002
AXIS M7014 Video Encoder is a compact and easy-to-use 4-channel video encoder with good video performance. It can simplify migration to network video without upgrading existing camera systems.
AXIS M7014 provides edge storage through a micro SDHC memory card slot. It supports all types of analog cameras including PTZ and PTZ domes. The video encoder features both RS-422 and RS-485 for controlling analog PTZ cameras.
  • Efficient 4-channel solution
  • Affordable, yet powerful
  • The easy way to a smarter CCTV system
    AXIS M7014 is perfect for small and medium analog video installations, especially where an IP network infrastructure is already in place. It is designed for installation close to the cameras. Its size also makes it ideal for use in discreet surveillance applications, for example, in retail stores and banks, and in camera housings. AXIS M7014 is powered over Ethernet using the same cable as for data transmission, which simplifies installation. A power supply is also included in the package.
  • Reduced bandwidth and storage
    AXIS M7014 can deliver two simultaneous video streams, one in H.264 and another in motion JPEG, at 15 frames per second in resolutions up to D1. The H.264 video compression format drastically reduces bandwidth and storage requirements without compromising image quality. Motion JPEG is supported for increased flexibility.
AXIS M7014 Video Encoder - video server - 4 channels
Video server - 4 channels
Compression Format
MJPEG, H.264
TV System
NTSC/PAL
Image Resolution
176x120 (NTSC), 720x480 (NTSC), 720x576 (PAL), 176x144 (PAL)
10.9 cm x 16 cm x 3.7 cm
0.57 kg
Country Kits
Europe
1 year
Video server
Video Channels
4
TV System
NTSC/PAL
Image Resolution
Compression Format
MJPEG, H.264
Package Content
Manual, software, video server, mounting kit
Software Included (Y)
Drivers & Utilities
Country Kits
Europe
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1
Warranty
1 year
Video Server
Frame Rate
15 fps
CPU
ARTPEC-4
RAM
512 GB
Flash Memory
128 MB
SD memory card slot, video motion detector, Pan/Tilt/Zoom support
DDNS Support
Web Server
Network Interfaces
Ethernet 10Base-T/100Base-TX
Supported Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, IGMP, QOS
Power over Ethernet (PoE), E-mail alert
Video Input Ports
BNC x 4
Camera Control Interface (PTZ)
RS-422/485
Network Port
10/100Base-T
10.9 cm
16 cm
3.7 cm
0.57 kg
50 °C
20 - 80% (non-condensing)
8DWL C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.52
