Axis M7001 1channel video encoder H264&MJPEG
Quicklinx: 83YCWS00 Mfr#: 0298-001
The one-channel AXIS M7001 Video Encoder offers a highly compact design with superb H.264 performance. It provides an easy and cost-effective solution for integrating small or large numbers of analog CCTV cameras into an IP-based video surveillance system.
The palm-sized, standalone AXIS M7001 is designed for installation close to an analog camera. It supports all types of analog cameras including PTZ (pan/tilt/zoom) and PTZ domes. AXIS M7001 is perfect for small and large analog video installations, especially where an IP network infrastructure is already in place. Its small size also makes it ideal for use in discreet surveillance applications, for example, in retail stores and banks, and in camera housings.
  • High performance, single channel solution
  • The easy way to a smarter CCTV system
  • Reduced bandwidth and storage
    AXIS M7001 can deliver two simultaneous video streams, one in H.264 and another in Motion JPEG, at full frame rate in all resolutions up to D1 (720 x 480 in NTSC, 720 x 576 in PAL). The H.264 video compression format drastically reduces bandwidth and storage requirements without compromising image quality. Motion JPEG is supported for increased flexibility. The video encoder also provides video motion detection. AXIS M7001 is powered over Ethernet using the same cable as for data transmission, which simplifies installation.
AXIS M7001 Video Encoder - video server - 1 channels
Video server - 1 channels
Compression Format
MJPEG, H.264
TV System
NTSC/PAL
Image Resolution
176x120 (NTSC), 720x480 (NTSC), 720x576 (PAL), 176x144 (PAL)
3.7 cm x 10.1 cm x 3 cm
82 g
1 year
Video server
Video Channels
1
Audio Channels
1
TV System
NTSC/PAL
Image Resolution
Compression Format
MJPEG, H.264
Package Content
Manual, software, video server, mounting kit
Software Included (Y)
Drivers & Utilities
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, EN 60950-1
Warranty
1 year
Video Server
Frame Rate
25 fps (PAL), 30 fps (NTSC)
CPU
ARTPEC-3
RAM
64 MB
Flash Memory
128 MB
Motion detection, PTZ support, PAL/NTSC auto-sensing input
DDNS Support
Web Server
Network Interfaces
Ethernet 10Base-T/100Base-TX
Supported Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, HTTP over SSL, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, Bonjour, RTCP, IGMP
Power over Ethernet (PoE), E-mail alert, IP address filtering, firmware upgradable
Video Input Ports
BNC x 1
Audio Input Ports
Sub-mini phone 2.5 mm x 1
Camera Control Interface (PTZ)
RS-422/485
Network Port
10/100Base-T
3.7 cm
10.1 cm
3 cm
82 g
50 °C
20 - 80%
