AXIS M5014 PTZ Dome Network Camera is a palm-sized, HDTV 720p pan/tilt/zoom camera that is affordably priced for remote and discreet monitoring of indoor areas such as stores, banks, hotels, office lobbies, restaurants and warehouses.
Discreet design with broad coverage
AXIS M5014 PTZ Dome Network Camera is a palm-sized, HDTV 720p pan/tilt/zoom camera that is affordably priced for remote and discreet monitoring of indoor areas such as stores, banks, hotels, office lobbies, restaurants and warehouses. -
HDTV-quality and multiple video streams
HDTV 720p entails a 1280 x 720 resolution, progressive scan, HDTV color fidelity, full frame rate and a 16:9 format. AXIS M5014 supports multiple H.264 and Motion JPEG video streams. -
Protective casing and easy installation on ceilings
With an IP51-rating, the camera is dustproof and protected from dripping water, enabling video to be taken even when a sprinkler system is activated. AXIS M5014 is designed for quick and easy installation. The camera is powered with Power over Ethernet (PoE) using a PoE switch or midspan, which eliminates the need for power cables and reduces installation costs. -
Audio support and intelligent capabilities
The built-in microphone enables users to listen in remotely and audio to be recorded. Audio detection allows unusual sounds or noise detected during off-hours to trigger alarm events. The microSD/SDHC card slot enables several days of recording on a microSDHC card.
- AXIS M5014 PTZ Dome Network Camera - network surveillance camera
- Network surveillance camera - pan / tilt / zoom - dustproof / waterproof
- Audio
- Yes: built-in microphone
- Camera Mount Type
- Ceiling mount
- 13 cm x 13 cm x 5.6 cm
- 330 g
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1280 x 720
- Frame Rate (max)
- 30 frames per second
- Video Modes
- 720p
- Optical Sensor Type
- CMOS - 1/4"
- Minimum Illumination
- 1.4 lux - colour - F1.8
- Focal Length Control
- Fixed focal
- Focal Length
- 3.6 mm
- Lens Iris
- F/1.8
- Panning Range (degree)
- 180
- Tilting Range (degree)
- 90
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Motion sensor, Backlight Compensation (BLC), sharpness control, white balance, colour control, alarm function, progressive scanning, brightness control, Power over Ethernet, ONVIF support
- 1-year warranty
- Environmental Parameters (operating)
- 0 °C - 45 °C; 10 - 85% (non-condensing) relative humidity
- Audio Support
- Camera Mount Type
- Ceiling mount
- Wired
- 13 cm
- 13 cm
- 5.6 cm
- 330 g
Camera
- Colour - pan / tilt / zoom - dustproof / waterproof
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 720
- Video Modes
- 720p
- Digital Zoom
- 3
- Exposure Range
- 1/6 sec - 1/25000 sec
- Video Capture
- 1280 x 720 @ 30 fps
- RAM
- 256 MB
- Flash Memory
- 128 MB
Image Sensor
- CMOS 1/4"
Lens Construction
- Fixed focal
- Focal Length
- 3.6 mm
- Lens Iris
- F/1.8
- Horizontal Field of View (degree)
- 60
Panning
- Range (degree)
- 180
- Speed (degree/sec)
- Up to 100
Tilting
- Range (degree)
- 90
- Up to 100
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, IGMP, SSL, QOS
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- C-Tick, VCCI Class B ITE, EN55024, EN55022 Class A, CISPR 22, EN 61000-6-1, FCC Part 15 B, ICES-003 Class A, EN 61000-6-2, EN 60950-1, KCC Class A
- Power Requirements
- PoE
- Software Included
- Drivers & Utilities
- Limited warranty - 1 year
- 0 °C
- 45 °C
- Relative Humidity (operating)
- 10 - 85% (non-condensing)
