Axis M3048-P Ultra Compact Indoor Fixed Dome Camera
Quicklinx: D5K6WS00 Mfr#: 01004-001
  • microSDHC Card
  • microSD Card
11 in stock
£544.06 ex VAT
£652.87 inc VAT
Are you looking for an affordable and compact network camera that provides complete overview of your premises? From retail stores to small offices, AXIS M3048-P Network Camera is ideal for any location where high quality 360° video surveillance is required to help protect your assets.
  • Get the overview
    AXIS M3048-P delivers outstanding 360° panoramic overview of smaller premises with a single camera. With its 12 MP sensor and full frame rate (up to 30 fps), it gives you complete and sharp overview, as well as allows you to zoom in to analyze live or recorded video footage. Whether an incident occurred in the middle of the space, or in a far corner, you can see distortion-free views of a specific area thanks to dewarping.
  • Compact and discreet
    A sleek, no-dome design means AXIS M3048-P is easily concealed from view. AXIS M3048-P is made from environment-friendly recycled plastics. The camera can also be repainted to blend in discreetly and seamlessly with your interior color scheme.
  • Easy to install, affordable to run
    Affordably priced AXIS M3048-P can be easily installed on walls or ceilings. It can also be mounted on a pendant or installed recessed. The camera is delivered factory-focused out of the box, so no focusing is required. And total costs are further reduced by Axis Zipstream technology, which preserves important details in full image quality, while reducing storage and bandwidth by up to 50%.
AXIS M3048-P - network surveillance camera
Network surveillance camera - fixed dome
10.1 cm x 10.1 cm x 4.6 cm
240 g
White
Wired
Camera
Max Resolution
2880 x 2880
Frame Rate (max)
30 frames per second
Motion Detection
Optical Sensor Type
CMOS - 1/1.7" - 12 MP
Minimum Illumination
0.35 lux F2.8 - 50 IRE
Focal Length Control
Fixed focal
Focal Length
1.65 mm
Lens Iris
F/2.8 - fixed iris
Panning Range (degree)
-180 to +180
HDMI, Ethernet 10Base-T/100Base-TX
Voltage
PoE
Sharpness control, white balance, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, Video Motion Detection Technology, active tampering alarm, digital PTZ function, 360° monitoring, Variable Bitrate (VBR), video analytics, Zipstream technology, Pixel Counter Support, digest authentication
3-year warranty
Environmental Parameters (operating)
0 °C - 40 °C; 10 - 85% (non-condensing) relative humidity
Wired
10.1 cm
10.1 cm
4.6 cm
240 g
Camera
Colour - fixed dome
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
2880 x 2880
Motion Detection
Exposure Range
1/2 sec - 1/25000 sec
Digital Video Capture Resolution
640 x 240, 1920 x 1440, 480 x 480, 640 x 360, 2048 x 1152, 480 x 360, 2560 x 1440, 2880 x 2880, 2560 x 720, 1920 x 720
Frame Rate (max)
RAM
1024 MB
Flash Memory
256 MB
Image Sensor
12 MP CMOS 1/1.7"
Lens Construction
Fixed focal
Focal Length
1.65 mm
Lens Iris
F/2.8 fixed iris
Horizontal Field of View (degree)
185
Vertical Field of View (degree)
185
Panning
Range (degree)
-180 to +180
Video
HDMI
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
Ports
LAN/power - RJ-45 , HDMI
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
CISPR 22 Class A, EN55024, EN 61000-6-1, ICES-003 Class A, EN 61000-6-2, IEC 60068-2-27, IEC 60068-2-6, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, VCCI Class A, KN35, EN 62368-1, EN 55032 Class A, KCC KN32 Class A
White
Power Requirements
PoE
5.6 Watt
Limited warranty - 3 years
Relative Humidity (operating)
Brand: Axis
Price Range Ex VAT: 500 - 750
