AXIS M3014 Fixed Dome Network Camera is an ultra-compact fixed dome with an innovative and unique camera design. It is specifically developed for recessed mounting in drop ceilings, creating an unmatched discreet solution for network video surveillance - measuring 9 cm (3.6") in diameter and barely sticking out 3 cm (1.1") from the ceiling.
AXIS M3014 is a 1 megapixel network camera using progressive scan technology. The camera offers multiple streams that can be individually optimized in H. 264 as well as Motion JPEG. The H. 264 compression enables optimization for bandwidth and storage efficiency by significantly reducing the bit rate.
- AXIS M3014 Fixed Dome Network Camera - network surveillance camera - dome
- Network surveillance camera - fixed - dome
- 9.2 cm x 9.2 cm x 10.5 cm
- 260 g
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1280 x 800
- Frame Rate (max)
- 30 frames per second
- Video Modes
- 720p
- Optical Sensor Type
- CMOS - 1/4" - 1 MP
- Minimum Illumination
- 1 lux F2.0
- Focal Length
- 2.8 mm
- Lens Iris
- F/2.0 - fixed iris
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Motion sensor, Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, e-mail alerts, image mirror, Privacy Mask Function
- 1-year warranty
- Environmental Parameters (operating)
- 0 °C - 45 °C; 20 - 80% (non-condensing) relative humidity
- Form Factor
- Dome
- Wired
- 9.2 cm
- 9.2 cm
- 10.5 cm
- 260 g
Camera
- Colour - fixed
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 800
- Video Modes
- 720p
- Exposure Range
- 1/25000 sec - 1/6 sec
- 1 lux F2.0
- Video Capture
- 1280 x 800 @ 30 fps
- RAM
- 128 MB
- Flash Memory
- 128 MB
Image Sensor
- 1 MP CMOS 1/4"
Lens Construction
- Focal Length
- 2.8 mm
- Lens Iris
- F/2.0 fixed iris
- Horizontal Field of View (degree)
- 80
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, IGMP, QOS
- Interfaces Details
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
- FCC Class B certified, C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, MIC Class B, KCC Class B
- Power Requirements
- PoE
- Software Included
- Drivers & Utilities
- Limited warranty - 1 year
- 0 °C
- 45 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
