Axis M3014 Fixed Dome Network Camera Fixed Iris 10/100
Quicklinx: 6562WS00 Mfr#: 0285-002
AXIS M3014 Fixed Dome Network Camera is an ultra-compact fixed dome with an innovative and unique camera design. It is specifically developed for recessed mounting in drop ceilings, creating an unmatched discreet solution for network video surveillance - measuring 9 cm (3.6") in diameter and barely sticking out 3 cm (1.1") from the ceiling.
AXIS M3014 is a 1 megapixel network camera using progressive scan technology. The camera offers multiple streams that can be individually optimized in H. 264 as well as Motion JPEG. The H. 264 compression enables optimization for bandwidth and storage efficiency by significantly reducing the bit rate.
  • Innovative, unique camera design
  • High-performance compression and streaming capabilities
AXIS M3014 Fixed Dome Network Camera - network surveillance camera - dome
Network surveillance camera - fixed - dome
9.2 cm x 9.2 cm x 10.5 cm
260 g
Wired
Camera
Max Resolution
1280 x 960
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
1 lux F2.0
Focal Length
2.9 mm
Lens Iris
F/2.0 - fixed iris
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Motion sensor, Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, e-mail alerts, image mirror
1-year warranty
Environmental Parameters (operating)
0 °C - 45 °C; 20 - 80% (non-condensing) relative humidity
Dome
Wired
9.2 cm
9.2 cm
10.5 cm
260 g
United Kingdom, Europe
Camera
Colour - fixed
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 960
Exposure Range
1/25000 sec - 1/6 sec
1 lux F2.0
RAM
128 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/4"
Lens Construction
Focal Length
2.9 mm
Lens Iris
F/2.0 fixed iris
Horizontal Field of View (degree)
80
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, IGMP, QOS
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
FCC Class B certified, C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, MIC Class B, KCC Class B
Power Requirements
PoE
Power injector - external
Software Included
Drivers & Utilities
Limited warranty - 1 year
45 °C
Relative Humidity (operating)
