The affordably priced AXIS M3007-PV Network Camera is a 5-megapixel fixed mini dome that provides detailed, high quality 360° or 180° panoramic views of areas. The vandal- and dust-resistant indoor mini dome can be used to detect activities, track the flow of people and improve area management. The camera is ideal for retail stores, hotels, schools and offices.
AXIS M3007-PV offers different views: 360° overview and dewarped views such as panorama, double panorama and quad views. The quad view is suitable, for instance, when the camera is positioned at an intersection of corridors. The camera also provides four individually cropped out and dewarped view areas where users can digitally pan, tilt and zoom in on areas of interest. Multiple video streams in H.264 and motion JPEG can be sent simultaneously.
360° or 180° panoramic surveillance
The affordably priced AXIS M3007-PV Network Camera is a 5-megapixel fixed mini dome that provides detailed, high quality 360° or 180° panoramic views of areas. The vandal- and dust-resistant indoor mini dome can be used to detect activities, track the flow of people and improve area management. The camera is ideal for retail stores, hotels, schools and offices. -
Different views
AXIS M3007-PV offers different views: 360° overview and dewarped views such as panorama, double panorama and quad views. The quad view is suitable, for instance, when the camera is positioned at an intersection of corridors. The camera also provides four individually cropped out and dewarped view areas where users can digitally pan, tilt and zoom in on areas of interest. Multiple video streams in H.264 and motion JPEG can be sent simultaneously. -
Easy and flexible installation
AXIS M3007-PV can be mounted on a wall or ceiling. The camera comes focused at delivery, which shortens the installation time. It has a 2 m (6.6 feet) network cable attached and supports Power over Ethernet (IEEE 802.3af), which eliminates the need for power cables and reduces installation costs. -
Intelligent video and video management
AXIS M3007-PV offers video motion detection and active tampering alarm. In the 360° overview mode, the camera also supports the installation of intelligent video applications, such as people counting and heat mapping, through the AXIS Camera Application Platform. In addition, the camera's built-in microSDHC card slot enables several days of recording to be stored locally on a memory card.
- AXIS M3007-PV Network Camera - network surveillance camera - dome
- Network surveillance camera - fixed - dome - dustproof / vandal-proof
- 6.5 cm x 13.1 cm x 13.1 cm
- 590 g
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 2592 x 1944
- Frame Rate (max)
- 12 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/3.2"
- Minimum Illumination
- 0.6 lux F2.8
- Focal Length
- 1.3 mm
- Lens Mounting
- M12 mount
- Lens Iris
- Fixed iris
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, brightness control, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, Motion Detection Technology, Panorama Capture, digital PTZ function, password protection
- 1-year warranty
- Environmental Parameters (operating)
- 0 °C - 45 °C; 15 - 85% (non-condensing) relative humidity
- Form Factor
- Dome
- Wired
- 6.5 cm
- 13.1 cm
- 13.1 cm
- 590 g
Camera
- Colour - fixed - dustproof / vandal-proof
- Digital Video Format
- MJPEG, H.264, AVC
- Max Digital Video Resolution
- 2592 x 1944
- Motion Detection
- Exposure Range
- 1/24000 sec - 2 sec
- 0.6 lux F2.8
- Digital Video Capture Resolution
- 2592 x 1944, 160 x 90
- Frame Rate (max)
- RAM
- 512 MB
- Flash Memory
- 128 MB
Image Sensor
- CMOS 1/3.2"
Lens Construction
- M12 mount
- Focal Length
- 1.3 mm
- Lens Iris
- Fixed iris
- Horizontal Field of View (degree)
- 187
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Included Accessories
- Mounting kit
- C-Tick, VCCI Class B ITE, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, IEC 60950-1, EN 60950-1, KCC Class B, IP42, IEC 62262 IK08
- Power Requirements
- PoE
- Power Device
- 4.6 Watt
- Limited warranty - 1 year
- 0 °C
- 45 °C
- Relative Humidity (operating)
- 15 - 85% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £11.45 |
