AXIS M1034-W offers the choice of either a wireless or a wired connection to the network. It features Wi-Fi Protected Setup protocol, which simplifies the process of configuring logical security on wireless networks. The combination of the wireless 802.11 b/g/n standard and the WPS protocol assures user-friendliness and high network security, while enabling HDVT video to be streamed reliably over a wireless network.
Wireless capabilities
AXIS M1034-W offers the choice of either a wireless or a wired connection to the network. It features Wi-Fi Protected Setup protocol, which simplifies the process of configuring logical security on wireless networks. The combination of the wireless 802.11 b/g/n standard and the WPS protocol assures user-friendliness and high network security, while enabling HDVT video to be streamed reliably over a wireless network. -
Intruder alarm capabilities
The AXIS M1034-W integrates a passive infrared (PIR) sensor for detecting movement - even in the dark. It includes a white LED for illuminating the scene automatically at an event or when requested by the user. It also offers two-way audio communication with integrated microphone and speaker, allowing remote listening in on an area as well as communication with individuals directly or using recorded audio clips. -
Easy and flexible installation
The mounting stand can be installed on wall and ceiling. A mounting clamp allows the camera to be installed in shelves.
- AXIS M1034-W Network Camera - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- 5.9 cm x 4.1 cm x 9.5 cm
- 118 g
- White
- Connectivity Technology
- Wired, wireless
- Camera
- Max Resolution
- 1280 x 800
- Optical Sensor Type
- CMOS - 1/4"
- Minimum Illumination
- 1.2 lux F2.0
- Focal Length
- 2.8 mm
- Lens Iris
- F/2.0 - fixed iris
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Voltage
- DC 5 V
- Motion sensor, sharpness control, digital image rotation, white balance, colour control, alarm function, brightness control, contrast control, image mirror, built-in LED illuminator, Wi-Fi Protected Setup (WPS), digital PTZ function
- 1-year warranty
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wired, wireless
- 5.9 cm
- 4.1 cm
- 9.5 cm
- 118 g
- Localisation
- United Kingdom
Camera
- Colour - fixed
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 800
- Exposure Range
- 1/6 sec - 1/8000 sec
- 1.2 lux F2.0
- Video Capture
- 1280 x 800 @ 30 fps , 320 x 240 @ 30 fps
- RAM
- 256 MB
- Flash Memory
- 128 MB
Image Sensor
- CMOS 1/4"
Lens Construction
- Focal Length
- 2.8 mm
- Lens Iris
- F/2.0 fixed iris
- Horizontal Field of View (degree)
- 80
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, QOS, CIFS
- Alarm Inputs Qty
- 1
- Alarm Outputs Qty
- 1
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
- Included Accessories
- Stand
- C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, AS/NZS 4771, RSS-210, FCC Part 15 C, EN 61000-6-2, IEC 60950-1, EN 60950-1, ANATEL, TELEC, KCC Class B, EN 62311, EN 300 328, EN 301 489-1, EN 301 489-17
- White
- Power Requirements
- DC 5 V
- Power Device
- Power adapter - external
- Software Included
- Drivers & Utilities
- Limited warranty - 1 year
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
