AXIS M1025 delivers HDTV 1080p or 2-megapixel resolution in full frame rate, in multiple H.264 Motion and JPEG streams, individually optimized for different quality needs and bandwidth constraints. When connecting the camera via the HDMI output (Micro), the live view streaming can be viewed on a public monitor at HDTV 720p. With a wide horizontal field of view of 94 degrees, AXIS M1025 also offers a fixed lens with adjustable focus.
HDTV performances with HDMI
AXIS M1025 delivers HDTV 1080p or 2-megapixel resolution in full frame rate, in multiple H.264 Motion and JPEG streams, individually optimized for different quality needs and bandwidth constraints. When connecting the camera via the HDMI output (Micro), the live view streaming can be viewed on a public monitor at HDTV 720p. With a wide horizontal field of view of 94 degrees, AXIS M1025 also offers a fixed lens with adjustable focus. -
Functional for installation flexibility
If the need is to monitor narrow corridors or aisles, AXIS M1025 supports the Axis' corridor format that optimizes the surveillance of long areas. A mounting clamp and an extension tube are also available to fit in different installation possibilities. Designed for easy and flexible installation, AXIS M1025 can be powered either over Ethernet as well as with a 5 V DC input. The camera has support for on-board memory card, which together with AXIS camera companion offers a cost effective solution for price sensitive budgets.
- AXIS M1025 Network Camera - network surveillance camera
- Network surveillance camera - fixed
- 5.9 cm x 4.1 cm x 9.5 cm
- 144 g
- White
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS - 1/2.7" - 2 MP
- Minimum Illumination
- 1.5 lux F2.8
- Focal Length Control
- Fixed focal
- Focal Length
- 3.6 mm
- Focus Adjustment
- Manual
- Lens Iris
- F/2.8 - fixed iris
- HDMI, Ethernet 10Base-T/100Base-TX
- Voltage
- DC 4.9 - 5.1 V / PoE Plus
- Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), Privacy Mask Function, text stamp, active tampering alarm, digital PTZ function, notification picture to FTP, ONVIF V2.2 (Profile S) support, password protection
- 1-year warranty
- Environmental Parameters (operating)
- 0 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
- Wired
- 5.9 cm
- 4.1 cm
- 9.5 cm
- 144 g
- Localisation
- United Kingdom
Camera
- Colour - fixed
- Digital Video Format
- MPEG-4, MJPEG, H.264, AVC
- Max Digital Video Resolution
- 1920 x 1080
- Video Modes
- 1080p
- Exposure Range
- 1/6 sec - 1/8000 sec
- 1.5 lux F2.8
- Digital Video Capture Resolution
- 320 x 240, 1920 x 1080
- Frame Rate (max)
- RAM
- 256 MB
- Flash Memory
- 128 MB
Image Sensor
- 2 MP CMOS 1/2.7"
Lens Construction
- Fixed focal
- Focal Length
- 3.6 mm
- Lens Iris
- F/2.8 fixed iris
- Focus Adjustment
- Manual
- Horizontal Field of View (degree)
- 94.3
- Vertical Field of View (degree)
- 50.2
- Video
- HDMI
- Network Interface
- Ethernet 10Base-T/100Base-TX
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
- Ports
- LAN/power - RJ-45 , HDMI output
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Included Accessories
- Stand
- C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, IEC 60950-1, EN 60950-1, KCC Class B, VCCI Class B
- White
- Power Requirements
- Power Device
- Power adapter - external 2.4 Watt
- Software Included
- Drivers & Utilities
- Limited warranty - 1 year
- 0 °C
- 50 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
