AXIS 221 DAY & NIGHT NW CAMERA
Quicklinx: 40VJWS00 Mfr#: 0221-003
AXIS 221 Day & Night network camera, with a high-quality Pentax lens and progressive scan CCD, is ideal for professional indoor and outdoor monitoring over IP networks. Supported by the industry's largest base of surveillance applications, it reduces cabling requirements by providing built-in support for Power over Ethernet (IEEE802.3af). It boasts true Day & Night functionality and is capable of motion detection and advanced event handling including pre- and post-alarm image buffering. AXIS 221 delivers superior video quality at up to 60 fps. It supports simultaneous Motion JPEG and MPEG-4, allowing optimization both for image quality and bandwidth efficiency.
  • Robust design
    Built to withstand operating humidity ranges from 20 - 80% and temperatures up to 50°C, ensuring reliable performance in challenging environmental conditions.
  • High-quality imaging
    Features a 1/3" CCD optical sensor and a lens aperture of f/1.0, providing clear and detailed images even in low-light conditions.
  • Advanced connectivity
    Equipped with Ethernet 10Base-T/100Base-TX interface, allowing for seamless integration into existing network infrastructures and easy management.
  • Versatile surveillance
    Supports both color and B&W modes, along with a progressive scan CCD system, to deliver superior video quality for diverse surveillance needs.
  • Efficient operation
    The camera's fixed mechanical design and external power adapter facilitate straightforward installation and maintenance, enhancing operational efficiency.
AXIS 221 Network Camera - network surveillance camera
Network surveillance camera - fixed
8.8 cm x 18.6 cm x 4.9 cm
0.6 kg
Wired
Camera
Max Resolution
640 x 480
Optical Sensor Type
CCD - 1/3"
Focus Adjustment
(min distance 30 cm)
Lens Iris
F/1.0
Progressive scan CCD system, IR filter
Environmental Parameters (operating)
5 °C - 50 °C; 20 - 80% relative humidity
Wired
8.8 cm
18.6 cm
4.9 cm
0.6 kg
Camera
Colour - fixed
Digital Video Format
MPEG-4, MJPEG
Max Digital Video Resolution
640 x 480
Exposure Range
2 sec - 1/25000 sec
RAM
32 MB
Image Sensor
CCD 1/3"
Lens Construction
Lens Iris
F/1.0
Min Focus Distance
30 cm
Network Interface
Interfaces Details
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x management - RS-422/485 - terminal block , 1 x management - RS-232 - 9 pin D-Sub (DB-9)
CSA, UL, C-Tick, VCCI Class B ITE, EN 60950, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, AS/NZS 3548, EN 61000-6-2
Power adapter - external
Software Included
Drivers & Utilities
Microsoft Windows 98, Microsoft Windows NT 4.0, Microsoft Windows 2000, Microsoft Windows Millennium Edition, Microsoft Windows XP
Additional Requirements
AGP graphics card with 32MB of memory
System Requirements Details
Pentium III - 500 MHz - RAM 128 MB
5 °C
50 °C
Relative Humidity (operating)
20 - 80%
