The AXIS 211 network camera, with vari-focal auto iris lens, is ideal for professional IP-based indoor and outdoor monitoring and security surveillance applications. Boasting the industry's largest application support, it has built-in web server, Power over Ethernet (802.3af compliant), motion detection, advanced event handling, and delivers superior video quality at up to 30 fps in full VGA 640x480 resolution. In addition the AXIS 211 is upgradeable to MPEG-4 supporting Advanced Simple profile. The MPEG-4 implementation works simultaneously with the Motion JPEG which is ideal for recording. The MPEG-4 is fully standards compliant with transportation under RTP/RTSP for multicast operation.
- AXIS Network Camera 211 - network surveillance camera
- Network surveillance camera - fixed
- 9.5 cm x 17.2 cm x 3.8 cm
- 0.3 kg
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 640 x 480
- Optical Sensor Type
- Super HAD CCD - 1/4" - 0.3 MP
- Focus Adjustment
- (min distance 0.5 mm)
- Lens Iris
- F/1.0
- Ethernet 10Base-T/100Base-TX
- Motion sensor, digital image rotation, progressive scanning
- Environmental Parameters (operating)
- 5 °C - 45 °C; 20 - 80% relative humidity
- Wired
- 9.5 cm
- 17.2 cm
- 3.8 cm
- 0.3 kg
Camera
- Colour - fixed
- Digital Video Format
- MPEG-4, MJPEG
- Max Digital Video Resolution
- 640 x 480
- Supported Image Formats
- JPEG
- RAM
- 16 MB
Image Sensor
- 0.3 MP Super HAD CCD 1/4"
Lens Construction
- Lens Iris
- F/1.0
- Min Focus Distance
- 0.5 mm
- Network Interface
- Network Protocols
- UPnP
- Interfaces Details
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45 , 2 x management - terminal block
- CSA, UL, C-Tick, VCCI Class B ITE, EN 60950, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, FCC Part 15 B, EMC, AS/NZS 3548
- Power Device
- Power adapter - external 9 Watt
- OS Required
- Microsoft Windows NT 4.0, Linux, Apple MacOS X, Microsoft Windows 98/ME/2000/XP
- 5 °C
- 45 °C
- Relative Humidity (operating)
- 20 - 80%
AXIS 211 OUTDOOR VERSO BUNDLE
