Avocent SwitchView DVI and USB KVM Switch, 2-port with built-in USB 2.0 hub and audio device sharing. Avocent SwitchView DVI 2-port KVM switch easily manages two USB DVI computers from a single USB keyboard, mouse and DVI monitor. With video resolutions up to 1920x1200, the SwitchView DVI delivers crisp images for today's high-end displays. Also, share speakers and microphone between PCs. Includes an integrated USB hub.
Manage two USB DVI computers from a single USB keyboard, mouse and DVI monitor;
Integrated USB 2.0 hub for sharing USB peripherals/devices;
1920 x 1200 video resolution ideal for desktop graphical applications;
Support for high-end applications, including DVI monitor and flat panel;
Support for USB PCs, Mac G3/G4, Imac;
Multimedia support including speaker and microphone;
Auto scanning allows easy monitoring of attached computers;
Easily add computers without powering down the KVM switch or attached computers.
PC access
It access from two to four PCs from a single keyboard, monitor and mouse. -
Audio support
Audio feature enables you to share speakers and a microphone between attached PCs. -
Ease of use
Pushbutton or keyboard hotkeys for channels elections; auto scanning allows easy monitoring of attached computers. -
Hot-plug capability
You can add or remove a desktop PC or laptop without turning off the switch or other attached servers.
- Avocent Switchview DVI - KVM / audio switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- KVM Users Qty
- 1 local user
- 16.5 cm x 10.2 cm x 4.3 cm
- 0.9 kg
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1200
- Built-in Devices
- USB Hub
- 2 x mini-USB 2.0 Type B , 2 x DVI-D , 2 x headphones mini-jack , 2 x microphone mini-jack , 2 x USB 2.0 Type A , 1 x DVI-D , 2 x USB 2.0 Type A
- Power Device
- External power adapter
- EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, EN 61000-3-3, EN55024, EN55022 Class B, FCC Part 15 B
- 16.5 cm
- 10.2 cm
- 4.3 cm
- 0.9 kg
- Limited warranty - 2 years
Customer reviews
Write a review for the Avocent SwitchView 2 Port USB 2.0 & DVI KVM & USB 2.0 HUB here!
Infuriating
Reviewed by Ado. Review Posted 21/01/2009
I'm writing to save you the infuriation I had with this product. It will recognise wireless keyboards and mice (on seperate radio receiving USB dongles) which is good, but 2 seperate units caused me the same problem making me think it's a manufacturing fault. Every 10 seconds the mouse pointer freezes and then begins again after 2 or 3 seconds. It's not something you can overlook or work with. Tried with wired and wireless mice and it produced the same problem.
Not great value for money for what it offers, but not terrible either.
Loses one point in ease of use because so many cables going into a small backplane means the last few are extra fiddley to fit. Loses a second because it won't sit flat on the desk unless you use blutack. The weight of the cables and plugs causes the front to rear in the air.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
