The cost-efficient SwitchView 1000 16-port KVM switch provides PS/2 and/or USB connectivity for users and target devices. This single-user switch has an on-screen display (OSD) and supports 2048 x 1536 video resolutions. The SwitchView 1000 16-port switch can be cascaded to support up to 256 target devices. With a 1U-high design, the switch does not compete for valuable rack space in SMB server rooms. Plus, it is flash upgradeable for fast and easy updates. The password protection feature gives you the benefit of added security access to your business-critical servers.
- Avocent Switchview 1000 - KVM switch - 16 ports
- KVM switch - 16 ports - stackable
- Enclosure Type
- 1U
- Subtype
- KVM
- Ports
- 16 x KVM port(s)
- KVM Users Qty
- 1 local user
- On-Screen Display
- 41 cm x 16.5 cm x 4.5 cm
- 2.2 kg
- Enclosure Type
- Desktop 1U
- Subtype
- KVM
- Ports
- 16 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- PS/2
- Max Units In A Stack
- 16
- Max Resolution
- 2048 x 1536
- On-Screen Display
- 16 x KVM HD-15 , 1 x network stack device input DB-15 , 1 x network stack device output DB-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x VGA HD-15 , 2 x USB Type A
- Power Device
- External power adapter
- UL, C-Tick, cUL, FCC
- 41 cm
- 16.5 cm
- 4.5 cm
- 2.2 kg
- 0 °C
- 40 °C
