Designed for the AutoView 1400, 1500 and 2000 KVM switches, this cable allows the connection of a CPU with a USB keyboard and mouse to the KVM switch via a single Cat5 cable. This advanced cabling solution reduces cable bulk, saves time and reduces cost, making it a valued component in your AutoView switching system.
- Avocent - video / USB cable - 2.13 m
- Video / USB cable
- Active cable (signal regeneration)
- Length
- 2.13 m
- Connectors
- 15 pin HD D-Sub (HD-15) , 4 pin USB Type A
- Connectors (Second End)
- RJ-45 - male
- Designed For
- AutoView AV3108, AV3216
- Video / USB cable
- Length
- 2.13 m
- Connectors
- RJ-45 - male
- Designed For
- Avocent AutoView AV3108, AV3216
