Avocent AutoView USB Cat 5 KVM Cable Kits 10ft
Quicklinx: 4TL5WS00 Mfr#: USBIAC-10
Designed for the AutoView 1400, 1500 and 2000 KVM switches, this cable allows the connection of a CPU with a USB keyboard and mouse to the KVM switch via a single Cat5 cable. This advanced cabling solution reduces cable bulk, saves time and reduces cost, making it a valued component in your AutoView switching system.
Avocent - video / USB cable - 3.05 m
Video / USB cable
Active cable (signal regeneration)
Length
3.05 m
Connectors
15 pin HD D-Sub (HD-15) , 4 pin USB Type A
Connectors (Second End)
RJ-45 - male
AutoView AV3108, AV3216
Video / USB cable
Length
3.05 m
Connectors
RJ-45 - male
Avocent AutoView AV3108, AV3216
