The AutoView 3200 switch is a 16-port KVM system providing server access for two remote digital users and one local analog user. The switch includes local USB peripheral support and provides convenient access to PS/2, Sun, and USB servers and serial-based devices. The on-board Web interface means that no additional software is required for remote server access.
- Avocent AutoView 3200 - KVM switch - 16 ports
- KVM switch - 16 ports - CAT5
- Enclosure Type
- 1U
- Subtype
- KVM
- Ports
- 16 x KVM port(s)
- KVM Users Qty
- 1 local user, 2 IP users
- Power
- AC 120/230 V (50/60 Hz)
- 43.2 cm x 28 cm x 4.4 cm
- 3.3 kg
- 2-year warranty
- Enclosure Type
- Desktop 1U
- Subtype
- KVM
- Ports
- 16 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- KVM IP Users Qty
- 2 IP users
- Server Connection Via Twisted Pair
- CAT5
- Keyboard / Mouse Interface
- PS/2
- Max Resolution
- 1280 x 1024 @ 75 Hz
- Server connection via twisted pair
- 16 x KVM RJ-45 , 1 x RS-232 - 9 pin D-Sub (DB-9) management , 1 x VGA HD-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 4 x USB Type A , 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 40 Watt
- Rack Mounting Kit
- Included
- UL, VCCI, C-Tick, GOST, cUL, GS, ICES-003, MIC, FCC
- 43.2 cm
- 28 cm
- 4.4 cm
- 3.3 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
