Avocent 1x4 PORT SwitchView SC KVM switch USB/dual/DVI-I
Quicklinx: 70Q3WS00 Mfr#: SC540-201
The Avocent SwitchView Secure KVM switches are field-proven, secure KVM switching solutions for government agencies. SwitchView Secure solutions allow users to switch safely between computers operating at different classification levels from a single set of peripherals, providing continuous access to critical data. With multiple security features, the Avocent KVM Secure Switch design prevents the transfer of data between the connected computers, ensuring data security isn't compromised.
Avocent Switchview SC540 - KVM / audio switch - 4 ports
Subtype
KVM
Ports
4 x KVM / audio
IDS
26.4 cm x 18.3 cm x 6.5 cm
1.8 kg
United Kingdom
Enclosure Type
Desktop
Subtype
KVM
Ports
4 x KVM / audio
Max Resolution
2560 x 1600 @ 60 Hz
IDS
Status Indicators
Port status
4 x USB Type B , 4 x speakers mini-jack , 4 x microphone input mini-jack , 8 x DVI-I (dual link) , 4 x USB Type A , 1 x speakers mini-jack , 1 x microphone input mini-jack , 2 x DVI-I (dual link)
Internal power supply
30 Watt
FCC Class A certified, UL, cUL, VCCI Class A ITE, ICES-003 Class A, EAL 4+, C-Tick Class A
United Kingdom
26.4 cm
18.3 cm
6.5 cm
1.8 kg
5 °C
