Avocent 1U 17 INCH LCD console
Quicklinx: 7CR0WS00 Mfr#: ECS17KMM8-201
The 17-inch LCD rack console and integrated KVM switches create a single, integrated access solution for SMB and server room environments. These solutions provide optimal support of PS/2 and USB systems. Out-of-band access to critical servers is non-intrusive to the network and reduces downtime.
Avocent LCD Console and KVM over IP Switch Integrated Tray - KVM console - 17"
KVM console - 17"
KVM Switch
USB - 8 ports
Keyboard, touchpad, 8 port KVM switch
Native Resolution
1280 x 1024 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Input Connectors
VGA
Voltage
AC 120/230 V
44.5 cm x 65.1 cm x 4.4 cm
Height (Rack Units)
1U
12.8 kg
United Kingdom
UL, VCCI, BSMI, GOST, GS, NOM, CB, EMC, FCC, ULC, RoHS, KCC
Display Type
KVM console / TFT active matrix
Diagonal Size
17"
Built-in Devices
8 port KVM switch
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Height (Rack Units)
1U
12.8 kg
Input
Keyboard, touchpad
KVM
KVM switch - 8 ports
Keyboard / Mouse Interface
USB
Keyboard (USB) , Mouse (USB) , VGA , USB , 8 x KVM (RJ-45)
Rack Mounting Kit
Included
MTBF
50,000 hour(s)
United Kingdom
Input Voltage
AC 120/230 V
Power Consumption (Typical)
33 Watt
50 °C
0 - 80%
