Create lessons on the go with the USB powered document camera anywhere, anytime. The U50 document camera displays vivid motion with 8x zoom. Take advantage of the built-in LED lights, built-in auto focus, and more features at a great price.
Setup so simple
It's as easy as 1-2-3. The U50 has only one USB cable to connect for a quick setup. Configuration made simple for everyday use. -
Clear quality display
Capture every student's attention with the U50's high quality picture. Easily magnify any detail in your lesson. -
Picture perfect
Who says geography or math can't be fun? Take a picture or capture video at high definition to jazz up all your learning visuals. -
Flexible design
Smart design for smart use and smart storage; bend it at any angle to teach or to stow away in a tight space. The U50 is light, portable and easy to use. -
Built-in LED lights
Every teacher needs a little bit of light when teaching in the dark. The U50 has a built-in LED light to illuminate any object under the camera.
- AVer AVerVision U50 - digital document camera
- Digital document camera - fixed
- Audio
- Yes: built-in microphone
- 24.8 cm x 39 cm x 44.8 cm
- 1.5 kg
- Connectivity Technology
- Wired
- Camera
- Colour - 1000 TVL
- Max Resolution
- 2592 x 1944
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- CMOS - 1/4" - 5 MP
- Focus Adjustment
- Automatic, manual
- USB 2.0
- Digital image rotation, digital image freeze, image mirror, USB powered, A3 document size support
- 2-year warranty
- Audio Support
- Wired
- 24.8 cm
- 39 cm
- 44.8 cm
- 1.5 kg
Camera
- Colour - fixed
- Horizontal Resolution (TV Lines)
- 1000
- Max Digital Video Resolution
- 2592 x 1944
- Digital Zoom
- 8
- Infrared LEDs
- Frame Rate (max)
- Still Image Capture Resolution
- 2592 x 1944
Image Sensor
- 5 MP CMOS 1/4"
Lens Construction
- Focus Adjustment
- Automatic, manual
- Computer Interface
- USB 2.0
- Ports
- 2 x USB 2.0 - 4 pin USB Type A , USB 2.0 - Mini-USB Type B
- Software Included
- A+ Suite
- Limited warranty - 2 years
AVerMedia U50 USB Visualiser
