At 192x, the M70 packs one of the biggest zooms you will find in a document camera. With this level of magnification, you can actually see chemical reactions at work, including yeast converting sugar water into energy and carbon dioxide. It looks like networks of gears and cogs in motion. A bonus is that when you are in digital zoom, you can move around the image while you are still zoomed in.
Megapixels, mega images, mega wows
Learning becomes wonderment when it's unfolding on the big screen and nothing puts on a show like the 5 megapixels of the M70 doc cam that's primed to show crisp text, bright images and vivid colors. The M70 is also engineered with a large imaging sensor to collect lots of light. More megapixels and more light mean better resolution and gorgeous detail for showcasing your classroom's best. -
See micro worlds in action
With the M70's optional microscope adaptor, you can explore nature's tiniest communities in action. Simply fit the adapter to any standard microscope eye-piece and you can now display small worlds on big screens. -
If only everything was 30 fps smooth
AVer Information suffers a little from attention deficit, so AVer Information made sure that the M70 shows only 30 fps video. That means it displays only smooth movement and images without any bumps, lags or freezes. Even math demonstrations are more captivating. -
Shed some light
Usually when the projector is on, the lights are off. Since the M70 is connected to a projector, it has built-in LED lights in the camera head to illuminate and display the objects underneath beautifully. -
Make a point
Need to explain a tricky concept or emphasize a key point? By simply plugging in an USB mouse into the M70, you can easily add annotations, highlights, arrows and captions. You don't need a computer.
- AVer AVerVision M70 - digital document camera
- Digital document camera
- Audio
- Yes: built-in microphone
- 18.2 cm x 45.2 cm x 50.4 cm
- 2.1 kg
- Connectivity Technology
- Wired
- Camera
- Colour - NTSC
- Optical Zoom
- 12 x
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- CMOS - 1/3.2" - 5 MP
- Focus Adjustment
- Automatic, manual
- USB, composite video, RGB, HDMI
- Cables Included
- 1 - USB cable - external , 1 - video / serial cable - external , 1 - VGA cable - external
- Audio recording, picture-in-picture capability, digital image rotation, digital image freeze, adjustable self timer, image mirror, built-in LED lights, SDHC-card slot, negative conversion, image split, built-in USB plug, video recording, Auto Zone Focus
- Microsoft Certification
- Compatible with Windows 7
- Audio Support
- Wired
- 18.2 cm
- 45.2 cm
- 50.4 cm
- 2.1 kg
Camera
- Video Format
- NTSC
- Max Digital Video Resolution
- 1920 x 1080
- Digital Zoom
- 16
- Frame Rate (max)
- Still Image Capture Resolution
- 1280 x 720, 1600 x 1200, 1024 x 768, 1280 x 1024, 1920 x 1080
Image Sensor
- 5 MP CMOS 1/3.2"
Lens Construction
- Optical Zoom
- 12 x
- Focus Adjustment
- Automatic, manual
- Video
- Composite video, RGB, HDMI
- Computer Interface
- USB
- 1 x microphone - input - mini-phone 3.5 mm , 1 x audio / video - HDMI output - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x USB , 1 x audio - output - mini-phone stereo 3.5 mm , 1 x display / video - VGA input - 15 pin HD D-Sub (HD-15) , 1 x display / video - VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial / video - RS-232/composite video output , 1 x video - composite video output - RCA
- Included Accessories
- Carrying case, remote control, anti-glare sheet
- Cables Included
- 1 x USB cable - external , 1 x video / serial cable - external , 1 x VGA cable - external
- FCC, RoHS
- Power Device
- Power adapter - external AC 120/230 V (50/60 Hz)
- Software Included
- Drivers & Utilities, AVer+ Software
- OS Required
- Microsoft Windows XP SP2, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7
