AVerMedia AVer TV DVB-T Super 007 M135
Quicklinx: 698PWS00 Mfr#: 61M135DV00AC
Digital terrestrial TV PCI receiver! The AVerTV DVB-T Super 007 is a digital terrestrial television receiver card that allows you to access free to air digital TV and digital radio signals using VHF/UHF antenna. It can be used to record and save TV and radio programs directly to your PC's hard disk in the original MPEG-2 format. It also can receive TV signal in HDTV format, so you can enjoy comprehensive digital TV programs in high quality on their computer monitors.
AVerMedia AVerTV DVB-T Super 007 - digital TV tuner - PCI
Digital TV tuner - DVB-T
Compatibility
MS Windows XP Media Centre compatible
Interface Type
PCI
Digital Video Format
MPEG-2
Channels preview, teletext, Electronic Program Guide (EPG)
Microsoft Windows XP Media Center Edition, Microsoft Windows Vista / 2000 / XP
Compatibility
Interface Type
PCI
Video
MPEG-2
1 x TV antenna - input
Compatible Slots
1 x PCI
