Product
Avaya B189 Conference VoIP Phone - H.323
Quicklinx: B5DZWS00 Mfr#: 700503700
Type: Conference VoIP phone
Handsets Included: [N/A]
Answer Machine: [N/A]
Nuisance Call Blocker: No
Big Button: No
£656.78 ex VAT
£788.13 inc VAT
The B189 IP conference phone is the most sophisticated conference phone yet from Avaya, designed specifically for use in Avaya Aura networks.
With a sleek, modern design, the B189 IP conference phone looks great in any executive boardroom or large conference room (even auditoriums). With Avaya OmniSound technology to maintain HD-quality sound for everyone on the call, an easy-to-navigate five-inch color touch screen display, and a wealth of built-in time-saving features, the B189 should be your first choice for an executive conference phone.
  • Now hear this
    Audio quality can often make or break a conference call. Avaya OmniSound technology helps ensure every participant is heard clearly, with noise suppression filters that virtually eliminate distracting background noise. The B189 conference phone has full duplex communications that prevents audio clipping, enabling 360-degree surround sound pick-up via its two powerful speakers and four built-in microphones. The B189 conference phone can pick up individual voices within a wide 20-foot radius. Extend that range with available expansion microphones.
  • Tap for efficient conference calls
    The Avaya B189 IP conference phone features a five-inch capacitive touch screen display to make call set-up and management quick and easy. Just tap through colorful and intuitive menus to start a call, add participants, mute, hold, transfer and more. Because the B189 conference phone is designed around the sophisticated Avaya Aura software platform, you can take advantage of any of the great features you already use with your existing Avaya phones. Simplicity and ease-of-use are two key principles of all Avaya solutions. The B189 conference phone is no exception.
Avaya B189 - conference VoIP phone
VoIP Protocols
H.323
Package Content
Conference phone console
Speakerphone
Yes (digital duplex)
Call Services
Call Transfer, Call Hold
Display
LCD display - colour - Yes
Display Features
LCD touch screen
Network Ports Qty
1 x Ethernet 10Base-T/100Base-TX/1000Base-T
Compatible Software
Avaya Communication Manager
Phone Features
Call Services
Dialer Type
Touch sensitive screen
Dialer Location
Base
Conference Call Capability
Speakerphone
Menu Operation
Firmware Upgradable
Conference Phone
Package Content
Console Microphone Reception Area
6.1 m
OmniSound 2.0
IP Telephony
VoIP
VoIP Protocols
H.323
Power Over Ethernet (PoE) Support
Network Ports Qty
Compatible Software
Display
Display Location
Base
Diagonal Size
5"
Display Resolution
800 x 480 pixels
Backlit
Display Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Russian, Spanish, Japanese, Korean
LCD touch screen
Supported Flash Memory Cards
SD Memory Card
USB , Audio line in
Big Button: No
Brand: Avaya
Price Range Ex VAT: 500 - 750
