Autodesk AutoCAD LT 2014 2D drafting software delivers the connected design tools you need, now available on Windows 8. Power your industry-specific workflows and speed documentation when you purchase AutoCAD LT as part of Autodesk AutoCAD Revit LT Suite or Autodesk AutoCAD Inventor LT Suite. Drive greater stakeholder involvement with new Design Feed social collaboration tools, and connect your designs to the world around you with live maps and geolocation capabilities. Help ensure file format compatibility and reliability using the latest DWG technology. And with time-saving tools like file tabs and an enhanced command line, AutoCAD LT helps boost productivity and streamline your design workflow.
Document your ideas and designs with tools and features designed for efficiency and accuracy
Create simple or complex drawings from standard shapes such as lines, arcs, and circles. Modify existing geometry with commands such as stretch, copy, rotate, and scale. Add annotations - including text, dimensions, and tables - to help convey your ideas with real-world dimensions and technical detail. -
Get industry-leading reliability and stability
Create drawings using the latest DWG technology and have confidence in data integrity when sharing your work. Maximize productivity by reducing time lost tackling corrupted or incompatible data. -
Incorporate external files
Reuse data and create richer documents by referencing external information from colleagues or clients - such as DWG files, JPEG and TIF images, Microsoft Excel spreadsheets, and DWF and PDF underlays - in your drawings. -
Benefit from AutoCAD compatibility
AutoCAD LT software is fully integrated with other Autodesk software products, making it easier for you to share data with others or expand your capabilities. -
Extend your desktop
With the computing capacity and capabilities of Autodesk 360 cloud services closely integrated with AutoCAD LT, you can store, review, and share files, keep track of file updates, and invite others to comment on designs. -
Drive efficient design documentation
Enhance your productivity with features and tools that can reduce the number of steps required to accomplish everyday tasks and create a drawing. -
Efficiently reuse content
Save time and standardize drawings by using blocks, adding dynamic properties to accommodate multiple sizes or views in a single block. Get quick access to frequently used content such as blocks, hatches, and commands with tool palettes.
- AutoCAD LT 2014 - New License - 1 seat
- Product Type
- New License
- Category
- Creativity application - CAD
- Packaged Quantity
- 5 (specifications are for single item)
- Licence Qty
- 1 seat
- Licence Pricing
- Commercial
- Licensing Details
- SLM
- Platform
- Windows
- Language
- Autodesk ML02
- Packaged Quantity
- Category
- Product Type
- New License
- Platform
- Windows
- Language
- Autodesk ML02
Licencing
- Licence Qty
- 1 seat
- Licence Pricing
- Commercial
- Details
- SLM
- Supported OS
- Microsoft Windows XP Professional x64 Edition SP2, Microsoft Windows 7 Home Premium (32/64 bits), Microsoft Windows XP Professional SP3, Microsoft Windows XP Home Edition SP3, Microsoft Windows 7 Professional (32/64 bits), Microsoft Windows 7 Ultimate (32/64 bits), Microsoft Windows 7 Enterprise (32/64 bits), Windows 8 (32/64 bits), Windows 8 Enterprise (32/64 bits), Windows 8 Pro (32/64 bits)
- Hardware Requirements
- Microsoft Windows 7 / Windows 8 (32 bits) - Pentium 4 - 3 GHz - RAM 2 GB - HD 4 GB , Microsoft Windows 7 / Windows 8 (32 bits) - Dual-Core Athlon - 3 GHz - RAM 2 GB - HD 4 GB , Microsoft Windows XP - Pentium 4 - 1.6 GHz - RAM 2 GB - HD 4 GB , Microsoft Windows XP - Dual-Core Athlon - 1.6 GHz - RAM 2 GB - HD 4 GB , Microsoft Windows (64 bit) - Pentium 4 RAM 2 GB - HD 4 GB , Microsoft Windows (64 bit) - Xeon RAM 2 GB - HD 4 GB , Microsoft Windows (64 bit) - Athlon 64 RAM 2 GB - HD 4 GB , Microsoft Windows (64 bit) - Opteron RAM 2 GB - HD 4 GB
- Additional Requirements
- DVD-ROM, Internet connection, 1024 x 768 monitor resolution, Internet Explorer 7 or later
