ATI ATI FirePro V3800 512M DDR3 PCIe
Quicklinx: 7HYDWS00 Mfr#: 100-505607
  • DisplayPort
This entry-level workstation solution with 512MB of DDR3 frame buffer memory is ideally suited for entry-level CAD users who work with small to medium sized models and fewer assembly parts and components. Its 30-bit display pipeline offers accurate color reproduction and advanced visual quality.
The ATI FirePro V3800 ultra parallel processing architecture optimizes throughput by automatically directing graphics horsepower where it's needed. Intelligent management of computational resources allows enhanced utilization of the GPU to enable real-time rendering of complex models and scenes while enabling increased frame rates when animating.
The ATI FirePro V3800 features two independent outputs enabling improved productivity at a low acquisition and operating cost. In addition, with native multi-card support, users can see more and do more using four displays being driven by two ATI FirePro V3800 products in the same workstation.
ATI FirePro professional graphics cards are thoroughly tested and certified with major Computer Aided Design (CAD) and Digital Content Creation (DCC) applications, ensuring a level of reliability not found in consumer graphics products.
  • AutoDetect technology
    As a user moves between applications, or opens new ones, the graphics driver settings are automatically configured for optimized performance.
  • Full 30-bit display pipeline
    Enables more color values than 24-bit products for more accurate color reproduction and superior visual fidelity.
  • Multi-View display
    With one DisplayPort output and one dual-DVI output, Multi-View enables up to two displays with independent display resolution, refresh rate, and display rotation settings.
  • Full Shader Model 5.0 support
    Create more complex geometry and scenes without taxing the CPU.
  • OpenCL 1.0
    Industry standard API - open, multiplatform development platform for enabling broad adoption of heterogeneous computing.
ATI FirePro V3800 - graphics card - FirePRO V3800 - 512 MB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
ATI FirePRO V3800
512 MB DDR3
Effective Memory Clock
1 GHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Interfaces Details
DisplayPort , DVI-I , VGA - with adapter , DisplayPort - with adapter
API Supported
DirectX 11, OpenGL 3.2
7.3 cm x 29.2 cm x 24.1 cm
Package Type
Retail
Microsoft Certification
Compatible with Windows 7
3-year warranty
Bus Type
PCI Express 2.0 x16
Graphics Engine
ATI FirePRO V3800
Max Resolution
2560 x 1600
Interfaces Details
API Supported
ATI CrossFire Pro Technology
Size
512 MB
DDR3 SDRAM
Effective Clock Speed
1 GHz
Bus Width
64-bit
Linux, Microsoft Windows Vista / XP / 7
Required Power Supply
350 W
Additional Requirements
CD-ROM, additional power connector
System Requirements Details
RAM 512 MB
CrossFire bridge
1 x DVI-VGA adapter , 1 x DisplayPort-DVI adapter
Supported Windows 7 Features
Windows Media Center
7.3 cm
29.2 cm
24.1 cm
0.7 kg
Package Type
Retail
Limited warranty - replacement - 3 years , Technical support - phone consulting - unlimited , Technical support - e-mail consulting - unlimited
