The VS182A HDMI Splitter is the perfect solution for anyone who needs to send one source of digital high definition video to two displays at the same time. It supports all HDMI-enabled equipment, such as DVD players, satellite set-top boxes and all HDMI displays.
The VS182A HDMI Splitter is HDCP (high bandwidth digital content protection) compliant, making it effective for use with all HDMI displays in home theater applications, as well as in corporate, educational and commercial settings.
- ATEN VanCryst VS182A - video/audio splitter - 2 ports
- Video/audio splitter - 2 ports
- Subtype
- HDMI
- Ports
- 2 x HDMI
- HDCP compliant, 3D support, 4K resolution support, 2K resolution support
- 12.5 cm x 8.15 cm x 2.5 cm
- 310 g
- Designed For
- ATEN VP2730
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Ports
- 2 x HDMI
- Max Resolution
- 4096 x 2160
- Max Video Bandwidth
- 340 MHz
- Status Indicators
- Power, link/activity
- 1 x HDMI input Type A , 2 x HDMI output Type A
- Power Device
- External power adapter
- 2 Watt
- RoHS, WEEE
- 12.5 cm
- 8.15 cm
- 2.5 cm
- 310 g
- 0 °C
- 50 °C
- 0 - 80% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
- Designed For
- ATEN VP2730
