The KH2508A KVM switch is a control unit that allows IT administrators to access and control multiple computers from two PS/2 or USB KVM consoles (one bus). Operators working at up to two consoles can independently and simultaneously take control of up to 8 computers. By daisy chaining up to 31 additional switches, as many as 256 computers can be controlled from the original KVM consoles.
This switch has been designed with unique and powerful features that enable administrators to manage their entire server room and data center devices easily and conveniently.
For example, the advanced adapter ID feature stores the adapter cable's configuration information - such as its ID, port name, OS, keyboard language, etc. This feature allows administrators to relocate servers to different ports without having to reconfigure the adapters.
A KH2508A installation provides one of the best, and most economical, solutions ATEN offers to the SMB market. There is no better way to save time, space, and money than with a KH2508A KVM switch.
- ALTUSEN KH2508A - KVM switch - 8 ports - TAA Compliant
- KVM switch - 8 ports - CAT5 - stackable
- Enclosure Type
- 1U
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- KVM Users Qty
- 2 local users
- Capacity
- Personal computers: 256
- On-Screen Display, firmware upgradable
- Power
- AC 120/230 V (50/60 Hz) 1 A
- 43.7 cm x 16.3 cm x 4.3 cm
- 2.8 kg
- TAA Compliant
- KVM switch - 8 ports - stackable
- Enclosure Type
- Desktop 1U
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- KVM Local Users Qty
- 2 local users
- Server Connection Via Twisted Pair
- CAT5
- Keyboard / Mouse Interface
- PS/2, USB
- Capacity
- Max Units In A Stack
- 32
- Max Resolution
- 1600 x 1200 @ 60 Hz
- Status Indicators
- Power, select
- 8 x KVM RJ-45 , 1 x RJ-11 management , 2 x keyboard (PS/2) , 2 x mouse (PS/2) , 2 x VGA HD-15 , 4 x keyboard (USB) / mouse (USB) Type A , 1 x network stack device input DB-25 , 1 x network stack device output DB-25
- Power Device
- Internal power supply
- Voltage Required
- Electric Current Required
- 1 A
- 7.2 Watt
- Mounting Kit
- Included
- Rack Mounting Kit
- Included
- TAA Compliant
- 43.7 cm
- 16.3 cm
- 4.3 cm
- 2.8 kg
- 0 °C
- 50 °C
- 0 - 80%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
