Aten Generic Aten 8-Port Cat 5 High Density KVM Switch
Quicklinx: 8QJXWS00 Mfr#: KH2508A
Type: KVM switch
Connectivity: KVM
Ports: 8
£633.28 ex VAT
£759.93 inc VAT
The KH2508A KVM switch is a control unit that allows IT administrators to access and control multiple computers from two PS/2 or USB KVM consoles (one bus). Operators working at up to two consoles can independently and simultaneously take control of up to 8 computers. By daisy chaining up to 31 additional switches, as many as 256 computers can be controlled from the original KVM consoles.
This switch has been designed with unique and powerful features that enable administrators to manage their entire server room and data center devices easily and conveniently.
For example, the advanced adapter ID feature stores the adapter cable's configuration information - such as its ID, port name, OS, keyboard language, etc. This feature allows administrators to relocate servers to different ports without having to reconfigure the adapters.
A KH2508A installation provides one of the best, and most economical, solutions ATEN offers to the SMB market. There is no better way to save time, space, and money than with a KH2508A KVM switch.
ALTUSEN KH2508A - KVM switch - 8 ports - TAA Compliant
KVM switch - 8 ports - CAT5 - stackable
Enclosure Type
1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Users Qty
2 local users
Personal computers: 256
On-Screen Display, firmware upgradable
AC 120/230 V (50/60 Hz) 1 A
43.7 cm x 16.3 cm x 4.3 cm
2.8 kg
TAA Compliant
KVM switch - 8 ports - stackable
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Local Users Qty
2 local users
Server Connection Via Twisted Pair
CAT5
Keyboard / Mouse Interface
PS/2, USB
Max Units In A Stack
32
Max Resolution
1600 x 1200 @ 60 Hz
Status Indicators
Power, select
8 x KVM RJ-45 , 1 x RJ-11 management , 2 x keyboard (PS/2) , 2 x mouse (PS/2) , 2 x VGA HD-15 , 4 x keyboard (USB) / mouse (USB) Type A , 1 x network stack device input DB-25 , 1 x network stack device output DB-25
Internal power supply
Electric Current Required
1 A
7.2 Watt
Mounting Kit
Included
Rack Mounting Kit
Included
TAA Compliant
43.7 cm
16.3 cm
4.3 cm
2.8 kg
50 °C
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Type: KVM switch
Connectivity: KVM
Ports: 8
Brand: Aten
Price Range Ex VAT: £500 - £750
