The CS22U is a 2-port USB cable KVM switch that provides a simple and quick method of selecting computers. This allows the CS22U unit to be hidden from sight, while the remote selection switch can be placed conveniently on the desktop. The CS22U's compact all-in-one design makes it ideal for multi platform desktop applications that require high resolution video.
- ATEN CS22U - KVM switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM port(s)
- KVM Users Qty
- 1 local user
- 7.7 cm x 8.2 cm x 2.5 cm
- 310 g
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 2048 x 1536
- 2 x keyboard (USB) Type A , 2 x VGA HD-15 , 2 x mouse (USB) Type A , 1 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A
- Cables Included
- 1 x keyboard / mouse / video cable - 90 cm
- DDC-2B
- 7.7 cm
- 8.2 cm
- 2.5 cm
- 310 g
- 3-year warranty
- 0 °C
- 50 °C
- 0 - 80%
ATEN CS22U 2 Port Desktop KVM Switch
