Aten 4-Port USB3.0 4K DisplayPort Dual Display KVMP Switch
Quicklinx: F3QFWS00 Mfr#: CS1944DP
Type: KVM / audio / USB switch
Connectivity: DisplayPort
Ports: 4
£510.14 ex VAT
£612.16 inc VAT
The ATEN CS1944DP desktop KVM switch helps organize your desktop. Especially when managing a multimedia workstation at a large organization, CS1944DP provides you with instant access to two or four computers, all through a single USB keyboard, USB mouse and two DisplayPort monitors.
Advanced video support provides a better-defined DisplayPort connection with video resolutions up to 4K (4096 x 2160 / 3840 x 2160 @ 60 Hz). Incorporating dual display capability, you are allowed to enjoy a wider screen and easily switch between two or four DisplayPort systems. In addition, featuring a built-in USB 3.1 Gen 1 hub, the CS1944DP delivers unprecedented data transfer rates up to 5 Gbps, allowing you to maximize multimedia operations.
Engineered to meet the ever-increasing demand for dual display, ultra-fast data transmission rates, and lossless 4K video resolution, the CS1944DP is specifically designed for where multitasking is needed such as design, financial trading, and video post-production.
ATEN CS1944DP - KVM / audio / USB switch - 4 ports
Subtype
DisplayPort
Ports
4 x KVM / audio
KVM Users Qty
1 local user
Firmware upgradable, HDCP compliant, 4K resolution support, metal housing, MST support, daisy-chaining support, built-in 2-port USB 3.1 hub, DP++ technology
USB 3.1 Gen 1
33.5 cm x 15.66 cm x 4.4 cm
1.51 kg
Enclosure Type
Desktop
Subtype
DisplayPort
Ports
4 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
4096 x 2160 @ 60 Hz
USB 3.1 Gen 1
Built-in Devices
USB 3.1 Gen 1 hub
2 x keyboard (USB) / mouse (USB) Type A , 2 x DisplayPort output , 2 x microphone input mini-jack , 4 x headphones output mini-jack , 1 x network stack device RJ-45 , 4 x USB 3.1 Gen 1 Type B , 2 x USB 3.1 Gen 1 Type A , 4 x microphone output mini-jack , 4 x headphones input mini-jack , 8 x DisplayPort input
External power adapter
Power Provided
12 V
5.76 Watt
8 x DisplayPort cable , 4 x SuperSpeed USB cable , 8 x audio cable
DisplayPort 1.2
33.5 cm
15.66 cm
4.4 cm
1.51 kg
50 °C
0 - 80% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Ports: 4
Brand: Aten
Price Range Ex VAT: £500 - £750
