The CS1644A 4-port USB DVI Dual View KVMP switch is a multi-application device that integrates a 4-port KVM switch with 2-port USB hub.
The CS1644A features multi-view capabilities, which allow two switches to be daisy chained for a dual, triple, or quadview display across multi-monitor installations. The CS1644A supports advanced nVidia 3D Vision ready 120 Hz 3D displaying, allowing you to manage various 3D visual effects. It allows you to manipulate all connected computers from a single console to save resources and work space. It enables each computer to access connected peripherals on a one-computer-at-a-time basis, making it ideal for users who need delicate visual effects and multi-tasking on several computers. The CS1644A is perfect for graphic designers, banking and financial consultants, gamers and medical professionals- demanding a high quality switch that provides stunning color, clarity and functionality.
- ATEN USB DVI Dual View KVMP Switch CS1644A - KVM / audio / USB switch - 4 ports
- KVM / audio / USB switch - 4 ports - cascadable
- Subtype
- KVM
- Ports
- 4 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- Firmware upgradable, built-in 2-port USB 2.0 hub, Video DynaSync, 3D support, nVidia 3D Vision ready
- 43.24 cm x 15.41 cm x 4.4 cm
- 2.32 kg
- System Requirements
- SunSoft Solaris, Apple MacOS, FreeBSD, Linux Kernel 2.6 or later, Microsoft Windows Vista / 2000 / XP
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Cascading Depth
- 3
- Max Resolution
- 2560 x 1600 @ 60 Hz
- Status Indicators
- Power, status, USB, operation mode, audio
- 4 x keyboard (USB) / mouse (USB) Type B , 4 x microphone input mini-jack , 4 x audio output mini-jack , 8 x DVI-I (dual link) , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x microphone input mini-jack , 1 x audio output mini-jack , 2 x DVI-I (dual link) , 2 x USB 2.0 Type A , 1 x cascading RJ-45
- Power Device
- External power adapter
- 12.19 Watt
- Cables Included
- 8 x DVI cable
- RoHS, WEEE, FCC Part 15 A
- OS Required
- 43.24 cm
- 15.41 cm
- 4.4 cm
- 2.32 kg
- 0 °C
- 50 °C
- 0 - 80% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
Aten 4-Port USB DVI Dual View KVMP Switch
