Aten 4 Port USB 2.0 DVI Dual link
Quicklinx: 917YWS00 Mfr#: CS1784A
Type: KVM / audio switch
Connectivity: KVM
Ports: 4
£229.95 ex VAT
£275.94 inc VAT
The CS1784A USB DVI dual link KVMP switch combines the capabilities of a 4-port KVM switch with a 2-port USB hub, while providing a DVI monitor interface and audio support. Moreover it carries advanced features, such as 120 Hz 3D display support, gaming keyboard compatibility and port selection/switching using a mouse, aimed at giving you flexibility, convenience and enjoyment.
ATEN CubiQ CS1784A - KVM / audio switch - 4 ports
Subtype
KVM
Ports
4 x KVM / audio
KVM Users Qty
1 local user
Firmware upgradable, built-in 2-port USB 2.0 hub, HDCP compliant
USB 2.0
27 cm x 8.7 cm x 5.5 cm
0.93 kg
Enclosure Type
Desktop
Subtype
KVM
Ports
4 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2560 x 1600
USB 2.0
1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x DVI-I (dual link) , 2 x audio output mini-jack , 2 x microphone input mini-jack , 2 x keyboard (USB) / mouse (USB) Type B , 4 x DVI-I (dual link) , 4 x audio output mini-jack , 4 x microphone input mini-jack , 2 x USB 2.0 Type A
External power adapter
10 Watt
RoHS
27 cm
8.7 cm
5.5 cm
0.93 kg
50 °C
0 - 80% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Connectivity: KVM
Ports: 4
Brand: Aten
