The Master View Dual-View CS-1742 USB KVM Switch brings dual-head video functionality to ATEN's USB KVM switch technology. Now, two (CS-1742) dual head computers can be accessed and controlled from a single console that consists of a USB keyboard, USB mouse, and two VGA, SVGA, or Multisync monitors. In addition, the CS-1742 incorporates a two port USB hub that allows each of the computers to share any USB peripherals connected to the hub.
- ATEN MasterView CS-1742 - KVM / audio / USB switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- Firmware upgradable
- 8.7 cm x 21 cm x 5.5 cm
- 0.82 kg
- System Requirements
- Apple MacOS, Linux, FreeBSD, Microsoft Windows Vista / 2000 / XP
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 2048 x 1536
- Status Indicators
- Port status, select, USB
- Keyboard / mouse / video / audio: 2 x 15 pin SPHD , Keyboard / mouse / video / USB: 2 x 15 pin SPHD , 2 x VGA HD-15 , 1 x microphone input mini-jack , 1 x speakers mini-jack , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 2 x USB Type A , 1 x RJ-11 management
- Power Device
- External power adapter
- 1.25 watt
- Cables Included
- 2 x keyboard / mouse / video / audio cable , 2 x keyboard / mouse / video / USB cable , 1 x keyboard / mouse adapter
- DDC-2B, RoHS, WEEE
- OS Required
- 8.7 cm
- 21 cm
- 5.5 cm
- 0.82 kg
- 0 °C
- 50 °C
- 0 - 80% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
