Aten 2 Port USB DisplayPort KVM Switch 4K
Quicklinx: CL3ZWS00 Mfr#: CS782DP-AT
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 2
£130.46 ex VAT
£156.55 inc VAT
With the ever-growing demand for higher video quality and the evolution of DisplayPort technology, 4K-enabled computers and displays are now widely adopted in visually-intensive and commercial applications. Offering up to 4K UHD resolution, the ATEN CS782DP is at home amongst these demanding scenarios and technological advancements.
The ATEN CS782DP 2-Port USB DisplayPort KVM Switch features 4K UHD video resolution and allows users to access two 4K-enabled computers from a single USB keyboard, USB mouse, and DisplayPort video console.
Doing so with ease, the CS782DP provides three convenient switching methods - using a remote port selector, mouse, or hotkeys for flexible access to any computer connected to the installation. The product even provides premium audio support for a complete multimedia solution. To round off the entire experience, the streamlined, space-saving design of CS782DP also makes it ideal for any working environment.
With its rich feature set, the CS782DP is designed to surpass all requirements in graphic design, animation, and video-editing applications.
ATEN CS782DP - KVM / audio / USB switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
Firmware upgradable, HDCP compliant, plastic housing, Remote Port Selector, 4K resolution support
9.3 cm x 9.37 cm x 2.68 cm
120 g
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
Status Indicators
KVM
2 x USB 2.0 Type B , 2 x DisplayPort , 2 x USB 2.0 Type A , 2 x audio mini-jack , 1 x audio mini-jack , 1 x remote control mini-jack
External power adapter
4 Watt
2 x USB cable - 1.8 m , 2 x DisplayPort cable - 1.8 m , 2 x audio cable - 1.8 m
9.3 cm
9.37 cm
2.68 cm
120 g
50 °C
0 - 80% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Connectivity: KVM
Ports: 2
Brand: Aten
