The KH1516Ai Cat 5 High-Density Over the NET KVM switch is a 16-port device in a 1U-high housing allowing local and remote operators to monitor and access the entire enterprise data center over the Internet using a web-based browser.
In addition to TCP/IP connectivity, the KH1516Ai provides KVM ports for a locally attached USB and/or PS/2 console and a Mini-USB port for a VNC Laptop console - allowing access and control from the data center, over the Net, or from a laptop's USB connection. This is a single bus unit, so although up to 32 users may be logged in simultaneously only one operator has control.
A special Message Board feature - similar to an internet chat program - lets all logged in users exchange information and communicate with each other to manage the installation cooperatively.
- ALTUSEN KH1516AI - KVM switch - 16 ports - rack-mountable
- KVM switch - 16 ports - cascadable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- KVM
- Ports
- 16 x KVM port(s)
- On-Screen Display, firmware upgradable
- Power
- AC 120/230 V (50/60 Hz)
- 43.7 cm x 16.1 cm x 4.4 cm
- 2-year warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- KVM
- Ports
- 16 x KVM port(s)
- Keyboard / Mouse Interface
- PS/2, USB
- Max Cascading Depth
- 512
- Max Resolution
- 1600 x 1200 @ 60 Hz
- 16 x KVM RJ-45 , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x cascading DB-25 , 1 x RJ-11 management
- Power Device
- Internal power supply
- Voltage Required
- 12.5 Watt
- Rack Mounting Kit
- Included
- RoHS
- 43.7 cm
- 16.1 cm
- 4.4 cm
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 0 - 80% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
