Aten 16 Port CAT-5 High Density KVM Switch over IP Daisy Chain
Quicklinx: C8KRWS00 Mfr#: KH1516AI
Type: KVM switch
Connectivity: KVM
Ports: 16
£800.60 ex VAT
£960.72 inc VAT
The KH1516Ai Cat 5 High-Density Over the NET KVM switch is a 16-port device in a 1U-high housing allowing local and remote operators to monitor and access the entire enterprise data center over the Internet using a web-based browser.
In addition to TCP/IP connectivity, the KH1516Ai provides KVM ports for a locally attached USB and/or PS/2 console and a Mini-USB port for a VNC Laptop console - allowing access and control from the data center, over the Net, or from a laptop's USB connection. This is a single bus unit, so although up to 32 users may be logged in simultaneously only one operator has control.
A special Message Board feature - similar to an internet chat program - lets all logged in users exchange information and communicate with each other to manage the installation cooperatively.
ALTUSEN KH1516AI - KVM switch - 16 ports - rack-mountable
KVM switch - 16 ports - cascadable
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
16 x KVM port(s)
On-Screen Display, firmware upgradable
43.7 cm x 16.1 cm x 4.4 cm
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
16 x KVM port(s)
Keyboard / Mouse Interface
PS/2, USB
Max Cascading Depth
512
Max Resolution
1600 x 1200 @ 60 Hz
16 x KVM RJ-45 , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x cascading DB-25 , 1 x RJ-11 management
Internal power supply
12.5 Watt
Rack Mounting Kit
Included
RoHS
43.7 cm
16.1 cm
4.4 cm
50 °C
0 - 80% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Type: KVM switch
Connectivity: KVM
Ports: 16
Brand: Aten
Price Range Ex VAT: £750 - £1000
