Using a NAS has never been easier. ADM's fresh and vibrant user interface features intuitive and familiar modern OS controls. With ASUSTOR NAS you'll never have to worry about a steep learning curve.
Customize your desktop to your liking. Whether it's organizing your Apps or changing your home screen wallpaper, ADM gives you the freedom to design the look and feel of your desktop. Furthermore, the "My Favorites" feature lets you pin frequently used applications to the taskbar allowing for easy access.
ASUSTOR NAS devices provide seamless cross-platform file sharing, allowing you to easily connect to your NAS device no matter if you are using Windows, Mac OS, or UNIX-like operating systems. The transfer protocols that you may use to connect to an ASUSTOR NAS device are as follows: Windows: CIFS/SMB, FTP and WebDAV; Mac OS X: AFP, SMB, NFS, FTP and WebDAV; Linux: NFS, SMB, FTP and WebDAV.
Additionally, ASUSTOR NAS devices feature the Network Recycle Bin. Any files you delete will be moved to the Recycle Bin, allowing you to restore any accidentally deleted files. Transfer protocols supported by the Recycle Bin include: CIFS/SMB, AFP, FTP and File Explorer.
ASUSTOR's dedicated mobile apps for iOS and Android allow you to get easy access to your NAS while you are out and about.
AiMaster is dedicated NAS management software for your mobile device. No matter if you are an individual user or IT administrator, AiMaster lets you conveniently manage your NAS while its comprehensive support for push notifications ensures that you stay up to date with the status of your system.
AiData lets you safely browse and access all the files stored on your NAS from your mobile device. Additionally, it allows you to stream multimedia content and view photos from your NAS as well as providing integration with Dropbox that gives you easy data management across the cloud.
Use your mobile device to control Download Center on your ASUSTOR NAS. Whether it's searching, downloading or managing tasks, AiDownload gets it done in the blink of an eye. Furthermore, when your downloads are completed, your mobile device will receive immediate notification.
ASUSTOR understands how important data security is to you. No matter the file type, RAID data protection can ensure the protection of your most treasured data. When used in conjunction with the multitude of built-in data backup features offered by ADM, you can rest assured that your most important digital assets are safely guarded. ADM's built-in data backup features include: Rsync Backup, FTP Backup, Cloud Backup, External Backup & One Touch Backup. All come with 2-way transfer support!
With in-house designed backup utility - Backup Plan, you can also schedule regular backups of the data on your Windows PC to your NAS device. Backup Plan also supports real-time backup. Files that are added or changed on your computer will be automatically uploaded to your NAS device.
Worried about how safe the data that you have put in public cloud storage is?
You can now use ASUSTOR NAS devices to effortlessly create a private cloud storage space for yourself. Using the exclusive Cloud Connect technology, you can access the data on your NAS device from almost anywhere on the planet. Whether by computer or mobile device, you need only an internet connection to access your NAS device from anywhere and at any time.
- ASUSTOR AS-204T - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Installed Devices / Modules Qty
- 0 (installed) / 4 (max)
- 17 cm x 23 cm x 18.55 cm
- Processor
- 1 x Intel Atom 1.2 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Networking
- Network adapter 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 4
- RAM
- 512 MB
- Power
- AC 120/230 V
- Storage Operating System
- ASUSTOR Data Master (ADM) 2.0
- System Requirements
- UNIX, Linux, FreeBSD, Microsoft Windows Server 2003, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 17 cm
- 23 cm
- 18.55 cm
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 512 MB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap - 2.5" / 3.5" shared
- Network adapter
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- TCP/IP, PPTP, iSCSI, FTP, SMB, DDNS
- Remote Management Protocol
- HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- Firewall protection, VPN support, VLAN support, wake on LAN (WOL), E-mail alert, IPv6 support, download client, event log, SSH support, iTunes server, Jumbo Frames support, SMS alert, BitTorrent Client, UPnP Media Server, bandwidth control, IPv4 support, surveillance station, cloud backup
- Encryption Algorithm
- SSL, TLS, 256-bit AES
Security DVR
- 4
- Expansion Bays
- 4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
- 1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A
- Cables Included
- 1 x network cable
- Built-in cooling fan
- VCCI, C-Tick, BSMI, FCC, AES-256
- Power Device
- Internal power supply
- Voltage Required
- AC 120/230 V
- 34 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - parts and labour - 2 years
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 19.4 dB
