Asustor 4-Bay NAS  Intel ATOM Dual Core  1GB DDR3  GbEx1
Quicklinx: BMQXWS00 Mfr#: AS-204TE
  • Atom
Your Digital Home Entertainment Center
AS-2XXTE series is officially ready for your living room, equipped with an HDMI output that allows the NAS to become a multimedia player. Sit back and relax and get ready enjoy your multimedia collection!
Quick and Easy File Access
The built-in File Explorer App allows you to access the files on your NAS through a Web browser. Enjoy drag and drop file transfers along with a directory structure view that lets you easily organize your data. Accessing files on your NAS never been easier.
Backup Everything
No matter if you are using Windows, Mac or even Linux, ASUSTOR provides you with suitable backup solutions and protocols to help you backup all your data.
Windows Environment ASUSTOR's exclusive Backup Plan utility lets you configure up to 6 different backup plans simultaneously. You can configure regularly scheduled backups of your important data and also sync the ever-changing files on your desktop to your NAS.
Mac Environment
ASUSTOR NAS supports Apple Time Machine backups allowing you to backup your Mac to your NAS. Different Mac users can also safely backup their computers to the same ASUSTOR NAS device.
Linux Environment
ASUSTOR NAS supports NFS/Rsync/SAMBA protocols giving you added flexibility when setting up your backup environment.
Your Cloud, Your Size
ASUSTOR NAS features RAID technology which allows you to combine multiple hard disks into a single logical storage volume giving you both storage and data protection benefits. ASUSTOR NAS also supports online hard disk capacity expansion allowing you to swap in higher capacity disks while enjoying complete access to all your data.
RAID levels supported by ASUSTOR NAS: RAID 0/1/5/6/10
RAID levels that support online capacity expansion: RAID 1/5/6/10
  • Your digital home entertainment center
    AS-204TE series is officially ready for your living room, equipped with an HDMI output that allows the NAS to become a multimedia player. Sit back and relax and get ready enjoy your multimedia collection!
  • Quick and easy file access
    The built-in File Explorer App allows you to access the files on your NAS through a web browser. Enjoy drag and drop file transfers along with a directory structure view that lets you easily organize your data. Accessing files on your NAS never been easier.
  • Backup everything
  • Your cloud, your size
ASUSTOR AS-204TE - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 4 (max)
17 cm x 23 cm x 18.55 cm
3.4 kg ()
1 x Intel Atom 1.2 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
Network adapter 10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
4
RAM
1 GB
AC 120/230 V
UNIX, Linux, FreeBSD, Microsoft Windows Server 2003, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
17 cm
23 cm
18.55 cm
3.4 kg ()
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
RAM
1 GB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD
Network adapter
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, FTP, DDNS
Remote Management Protocol
HTTP, HTTPS, SSH
Network Services Compatibility
DDNS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
VLAN support, E-mail alert, IPv6 support, backup server, event log, SSH support, iTunes server, Jumbo Frames support, SMS alert, BitTorrent Client, UPnP Media Server, IPv4 support, surveillance station, cloud backup
Encryption Algorithm
SSL, TLS, 256-bit AES
UPnP
Security DVR
4
Expansion Bays
4 (total) / 4 (free) x external - 2.5" / 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x HDMI output , 1 x audio out - mini-jack
Built-in cooling fan
VCCI, C-Tick, BSMI, FCC, AES-256
Internal power supply
AC 120/230 V
36 Watt
5 °C
35 °C
5 - 95%
Sound Emission
19.4 dBA
