Asustor 2-Bay NAS  Intel ATOM Dual Core  1GB DDR3 GbEx1
Quicklinx: BMQYWS00 Mfr#: AS-202TE
  • Atom
Better Price, Better Performance
ASUSTOR's ADM operating system combined with an Intel processor allows the 2 series to raise read and write performance to the max.
The 2 series also provides a total of 4 USB ports (2 x USB 3.0, 2 x USB 2.0) allowing you to simultaneously connect up to 4 external USB hard drives to expand your storage capacity.
Furthermore, AS-2TE series comes equipped with an HDMI port and audio jack allowing your NAS to transform into a multimedia player!
Your Digital Home Entertainment Center
AS-2XXTE series is officially ready for your living room, equipped with an HDMI output that allows the NAS to become a multimedia player. Sit back and relax and get ready enjoy your multimedia collection!
Quick and Easy File Access
The built-in File Explorer App allows you to access the files on your NAS through a Web browser. Enjoy drag and drop file transfers along with a directory structure view that lets you easily organize your data. Accessing files on your NAS never been easier.
The NAS That's Always With You
ASUSTOR offers multiple mobile apps that give you convenient access to your NAS while on the go. Cloud data access from anywhere: AiData Browse all the data on your NAS and even instantly share files from your NAS with friends. One stop searching and downloading: AiDownload Monitor any current download tasks on the NAS. As soon as download tasks are finished, your mobile device will be notified via push notification. Stay up to date with your NAS: AiMaster Via push notifications, you can always get a handle on your NAS system and backup status. Shutting down your NAS is also a breeze with AiMaster. Your NAS multimedia player remote: AiRemote Your mobile device can now become your remote control! Sit back and relax on your couch while you control media playback from your NAS with your mobile device.
Backup Everything
No matter if you are using Windows, Mac or even Linux, ASUSTOR provides you with suitable backup solutions and protocols to help you backup all your data.
Windows Environment ASUSTOR's exclusive Backup Plan utility lets you configure up to 6 different backup plans simultaneously. You can configure regularly scheduled backups of your important data and also sync the ever-changing files on your desktop to your NAS.
Mac Environment
ASUSTOR NAS supports Apple Time Machine backups allowing you to backup your Mac to your NAS. Different Mac users can also safely backup their computers to the same ASUSTOR NAS device.
Linux Environment
ASUSTOR NAS supports NFS/Rsync/SAMBA protocols giving you added flexibility when setting up your backup environment.
  • Better price, better performance
    ASUSTOR's ADM operating system combined with an Intel processor allows the 2 series to raise read and write performance to the max. The 2 series also provides a total of 4 USB ports (2 x USB 3.0, 2 x USB 2.0) allowing you to simultaneously connect up to 4 external USB hard drives to expand your storage capacity. Furthermore, AS-2TE series comes equipped with an HDMI port and audio jack allowing your NAS to transform into a multimedia player!
  • Your digital home entertainment center
    AS-202TE is officially ready for your living room, equipped with an HDMI output that allows the NAS to become a multimedia player. Sit back and relax and get ready enjoy your multimedia collection!
  • Quick and easy file access
  • The NAS that's always with you
  • Cloud data access from anywhere: AiData
  • One stop searching and downloading: AiDownload
  • Stay up to date with your NAS: AiMaster
  • Your NAS multimedia player remote: AiRemote
  • Backup everything
  • Windows environment
    ASUSTOR's exclusive backup plan utility lets you configure up to 6 different backup plans simultaneously. You can configure regularly scheduled backups of your important data and also sync the ever-changing files on your desktop to your NAS.
  • Mac environment
  • Linux environment
ASUSTOR AS-202TE - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 2 (max)
10.8 cm x 23 cm x 16.35 cm
1.87 kg ()
1 x Intel Atom 1.2 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, JBOD
Hard Drive
Standard
Network adapter 10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
4
RAM
1 GB
AC 120/230 V
UNIX, Linux, FreeBSD, Microsoft Windows Server 2003, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
10.8 cm
23 cm
16.35 cm
1.87 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
RAM
1 GB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
Standard
Network adapter
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, FTP, DDNS
Remote Management Protocol
HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
VLAN support, E-mail alert, IPv6 support, backup server, event log, SSH support, iTunes server, Jumbo Frames support, SMS alert, BitTorrent Client, UPnP Media Server, IPv4 support, surveillance station, cloud backup
Encryption Algorithm
SSL, TLS, 256-bit AES
UPnP
Security DVR
4
Expansion Bays
2 (total) / 2 (free) x external - 2.5" / 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x HDMI output
1 x network cable
Built-in cooling fan
VCCI, C-Tick, BSMI, FCC, AES-256
External power adapter
AC 120/230 V
19.7 Watt
Software Included
Drivers & Utilities
5 °C
35 °C
5 - 95%
Sound Emission
24 dBA
