Asus Zephyrus 14" OLED WQXGA+ Ryzen 9-8945HS RTX 4070 32GB 1TB
Quicklinx: HV6MWS00 Mfr#: GA403UI-QS060W
  • IEEE 802.11n
The ASUS ROG Zephyrus G14 combines exceptional performance with high-quality visuals and audio. It features an AMD Ryzen 9 processor and NVIDIA GeForce RTX 4070 graphics, ensuring smooth, detailed visuals on a 14-inch OLED display that presents content with vivid colors and deep blacks. The display, with a 100% DCI-P3 color gamut and Dolby Vision, provides sharp details and accurate colors.
The notebook comes with a Dolby Atmos compliant sound system, including AI noise-canceling and Smart Amplification technology, for an immersive sound experience. With its modern ports and Wi-Fi 6E support, connectivity is seamless, offering fast data transfer and reliable Internet connections. Its innovative cooling system maintains peak efficiency, making the ASUS ROG Zephyrus G14 suitable for both gamers and professionals.
  • Immersive audio experience
    Equipped with AI noise-canceling and a 3-microphone array, alongside Dolby Atmos compliant four speakers featuring Hi-Res Audio and Smart Amplification technology, this notebook delivers an immersive auditory experience that immerses you in every game, movie, or song.
  • Stunning visual fidelity
    The ASUS ROG Zephyrus G14 boasts a 14-inch OLED display with a WQXGA (2880 x 1800) resolution, 100% DCI-P3 color gamut, and VESA DisplayHDR 500 certification. Enhanced with Dolby Vision, Pantone Validated color accuracy, and a rapid 0.2 ms response rate, it ensures vibrant visuals and true-to-life colors.
  • Advanced cooling technology
    Featuring 0dB Ambient Cooling, vapor chamber cooling system, and Arc Flow Fans with anti-dust technology, the notebook maintains optimal performance by efficiently dissipating heat, even during intense gaming sessions.
  • High-speed connectivity
    With a comprehensive set of interfaces including USB4/DisplayPort, USB-C 3.2 Gen 2/DisplayPort, and HDMI, along with Wi-Fi 6E and Bluetooth 5.3 support, this notebook ensures you're always connected at the highest speeds.
  • Powerful performance
    Powered by an AMD Ryzen 9 8945HS processor with a max turbo speed of 5.2 GHz and paired with NVIDIA GeForce RTX 4070 graphics, 32 GB of LPDDR5X RAM, and a 1 TB NVMe SSD, the ASUS ROG Zephyrus G14 is built to handle demanding games and productivity tasks effortlessly.
ASUS ROG Zephyrus G14 GA403UI-QS060W - AI Ready - 14" - AMD Ryzen 9 - 8945HS - 32 GB RAM - 1 TB SSD
Notebook - AI Ready
Operating System
Win 11 Home
AMD Ryzen 9 8945HS / 4 GHz, up to 5.2 GHz / 24 MB Cache
32 GB LPDDR5X (provided memory is soldered)
Storage
1 TB SSD - NVMe
Display
14" OLED 2880 x 1800 / WQXGA @ 120 Hz
Graphics
NVIDIA GeForce RTX 4070 / AMD Radeon 780M
Video Memory
8 GB GDDR6 SDRAM
Gaming
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3
4-cell
Eclipse grey
31.1 cm x 22 cm x 1.63 cm
1.5 kg
Notebook - AI Ready
Operating System
Windows 11 Home
Processor / Chipset
CPU
Max Turbo Speed
5.2 GHz
Number of Cores
8-core
Cache
24 MB
RAM
32 GB (provided memory is soldered)
LPDDR5X SDRAM
Speed
6400 MHz
Rated Speed
6400 MHz
Storage
Main Storage
1 TB SSD M.2 PCIe 4.0 - NVM Express (NVMe)
Display
14" OLED
Resolution
2880 x 1800 (WQXGA)
V-Sync Rate at Max Res.
120 Hz
Widescreen
Image Aspect Ratio
16:10
Image Brightness
500 cd/m²
Colour Gamut
100% DCI-P3
Anti-glare, narrow edge, glass cover, VESA DisplayHDR 500, Dolby Vision, Pantone Validated, Delta E<1 calibration, 0.2 ms response rate
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
8 GB GDDR6 SDRAM
Gaming
Camera
Yes - 720p
Camera Features
IR camera, Windows Hello
Sound
Four speakers, 3-microphone array
Dolby Atmos
Audio Features
Output: Smart Amplification technology, Hi-Res Audio; Input: AI noise cancelling
Input
Keyboard, touchpad
Keyboard Backlight
1 RGB zone, 4 hot keys, N-key rollover, large touchpad
Communications
Wireless
Dual stream (2x2)
4-cell Lithium Ion
73 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
180 Watt, 19 V, 9.23 A
Connections & Expansion
Interfaces Details
USB4/DisplayPort (Power Delivery) , USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) , 2 x USB 3.2 Gen 2 , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (microSDXC UHS-II)
Eclipse grey
BIOS protection, ASUS Aura Sync technology, ROG Intelligent Cooling, vapor chamber cooling system, 0dB Ambient Cooling, Thermal Grizzly Hydronaut Thermal Compound, Arc Flow Fans, anti-dust 2.0 cooling system, ErgoLift, ROG Nebula Display
USB-C power adapter
TUV Rheinland Low Blue Light Certification
1.5 kg
