The ASUS ROG Zephyrus G14 combines exceptional performance with high-quality visuals and audio. It features an AMD Ryzen 9 processor and NVIDIA GeForce RTX 4070 graphics, ensuring smooth, detailed visuals on a 14-inch OLED display that presents content with vivid colors and deep blacks. The display, with a 100% DCI-P3 color gamut and Dolby Vision, provides sharp details and accurate colors.
The notebook comes with a Dolby Atmos compliant sound system, including AI noise-canceling and Smart Amplification technology, for an immersive sound experience. With its modern ports and Wi-Fi 6E support, connectivity is seamless, offering fast data transfer and reliable Internet connections. Its innovative cooling system maintains peak efficiency, making the ASUS ROG Zephyrus G14 suitable for both gamers and professionals.
Immersive audio experience
Equipped with AI noise-canceling and a 3-microphone array, alongside Dolby Atmos compliant four speakers featuring Hi-Res Audio and Smart Amplification technology, this notebook delivers an immersive auditory experience that immerses you in every game, movie, or song. -
Stunning visual fidelity
The ASUS ROG Zephyrus G14 boasts a 14-inch OLED display with a WQXGA (2880 x 1800) resolution, 100% DCI-P3 color gamut, and VESA DisplayHDR 500 certification. Enhanced with Dolby Vision, Pantone Validated color accuracy, and a rapid 0.2 ms response rate, it ensures vibrant visuals and true-to-life colors. -
Advanced cooling technology
Featuring 0dB Ambient Cooling, vapor chamber cooling system, and Arc Flow Fans with anti-dust technology, the notebook maintains optimal performance by efficiently dissipating heat, even during intense gaming sessions. -
High-speed connectivity
With a comprehensive set of interfaces including USB4/DisplayPort, USB-C 3.2 Gen 2/DisplayPort, and HDMI, along with Wi-Fi 6E and Bluetooth 5.3 support, this notebook ensures you're always connected at the highest speeds. -
Powerful performance
Powered by an AMD Ryzen 9 8945HS processor with a max turbo speed of 5.2 GHz and paired with NVIDIA GeForce RTX 4070 graphics, 32 GB of LPDDR5X RAM, and a 1 TB NVMe SSD, the ASUS ROG Zephyrus G14 is built to handle demanding games and productivity tasks effortlessly.
- ASUS ROG Zephyrus G14 GA403UI-QS060W - AI Ready - 14" - AMD Ryzen 9 - 8945HS - 32 GB RAM - 1 TB SSD
- Product Type
- Notebook - AI Ready
- Operating System
- Win 11 Home
- Processor
- AMD Ryzen 9 8945HS / 4 GHz, up to 5.2 GHz / 24 MB Cache
- Memory
- 32 GB LPDDR5X (provided memory is soldered)
- Storage
- 1 TB SSD - NVMe
- Display
- 14" OLED 2880 x 1800 / WQXGA @ 120 Hz
- Graphics
- NVIDIA GeForce RTX 4070 / AMD Radeon 780M
- Video Memory
- 8 GB GDDR6 SDRAM
- Gaming
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3
- Battery
- 4-cell
- Eclipse grey
- 31.1 cm x 22 cm x 1.63 cm
- 1.5 kg
- Product Type
- Operating System
- Windows 11 Home
Processor / Chipset
- CPU
- Max Turbo Speed
- 5.2 GHz
- Number of Cores
- 8-core
- Cache
- 24 MB
- RAM
- 32 GB (provided memory is soldered)
- Technology
- LPDDR5X SDRAM
- Speed
- 6400 MHz
- Rated Speed
- 6400 MHz
Storage
- Main Storage
- 1 TB SSD M.2 PCIe 4.0 - NVM Express (NVMe)
Display
- 14" OLED
- Resolution
- 2880 x 1800 (WQXGA)
- V-Sync Rate at Max Res.
- 120 Hz
- Widescreen
- Image Aspect Ratio
- 16:10
- Image Brightness
- 500 cd/m²
- Colour Gamut
- 100% DCI-P3
- Anti-glare, narrow edge, glass cover, VESA DisplayHDR 500, Dolby Vision, Pantone Validated, Delta E<1 calibration, 0.2 ms response rate
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 8 GB GDDR6 SDRAM
- Gaming
- Camera
- Yes - 720p
- Camera Features
- IR camera, Windows Hello
- Sound
- Four speakers, 3-microphone array
- Dolby Atmos
- Audio Features
- Output: Smart Amplification technology, Hi-Res Audio; Input: AI noise cancelling
Input
- Keyboard, touchpad
- 1 RGB zone, 4 hot keys, N-key rollover, large touchpad
Communications
- Wireless
- Dual stream (2x2)
- Technology
- 4-cell Lithium Ion
- Capacity
- 73 Wh
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 180 Watt, 19 V, 9.23 A
Connections & Expansion
- Interfaces Details
- USB4/DisplayPort (Power Delivery) , USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) , 2 x USB 3.2 Gen 2 , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSDXC UHS-II)
- Eclipse grey
- BIOS protection, ASUS Aura Sync technology, ROG Intelligent Cooling, vapor chamber cooling system, 0dB Ambient Cooling, Thermal Grizzly Hydronaut Thermal Compound, Arc Flow Fans, anti-dust 2.0 cooling system, ErgoLift, ROG Nebula Display
- Included Accessories
- USB-C power adapter
- TUV Rheinland Low Blue Light Certification
- 1.5 kg
