Asus ZenScreen MB166CR 16" Portable Monitor
Quicklinx: HTRSWS00 Mfr#: MB166CR
Diagonal Size: 16in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: USB
£113.04 ex VAT
£135.64 inc VAT
Sleek and portable design
ASUS ZenScreen™ is ideal for life on the road. This sleek portable display is light weight and has a slim profile, so it fits easily in any travel bag and is ready for productivity, anytime and anywhere.
One cable is all you need
ZenScreen MB166CR uses a single USB Type-C* connection for both power and video transmission from your host device. This means you have less cables to work with, so you get a neater work area.
Designed with Versatility
A 360° detachable kickstand allow you to screw-in with ease on the rear tripod socket, enabling easy tilt adjustments in either portrait or landscape mode. With the 360° kickstand design you can even put it on a tabletop mount with ease.
Work efficiently in portrait and landscape modes
With ASUS DisplayWidget Center software2,ZenScreen MB166CR can automatically sense its orientation and switch the display between landscape and portrait modes while connected to your laptop. Landscape mode is ideal for presentations and spreadsheets, while Portrait mode gives you a perfect view of items such as documents, books or websites.
Extend your workspace
The FHD (1920 x 1080) IPS panel delivers stunning visuals and 178° viewing angles, ensuring you get superb color and contrast even when viewing the screen from off-center positions.
ASUS blue light filter
Exclusive ASUS Ultra-Low Blue Light technology protects you from potentially harmful blue light. It offers four filter settings that are easily accessed through the onscreen display menu via the hotkey.
  • Portable design
    The ASUS ZenScreen MB166CR stands out with its portable form factor, making it an ideal companion for professionals on-the-go. Its lightweight design, complemented by a built-in kickstand, allows for easy setup and versatile viewing angles, ensuring productivity is never hampered, no matter the location.
  • Exceptional visual quality
    Experience stunning visual clarity with the 16-inch Full HD display, boasting a 178-degree viewing angle, 262,000 colors, and anti-glare coating. This monitor delivers vivid images and colors, making it perfect for both work and play.
  • Eye comfort technology
    Equipped with ASUS EyeCare Technology, the ZenScreen MB166CR minimizes eye strain during extended use. Features like Blue Light Filter technology and Anti-Flicker provide a more comfortable viewing experience, allowing you to work or enjoy your entertainment for longer periods without discomfort.
  • Enhanced connectivity
    With USB-C/DisplayPort interface, the monitor offers a seamless connection to a wide range of devices. This feature ensures easy Plug-and-Play setup, eliminating the hassle of multiple cables and adapters.
  • Energy efficient
    The ASUS ZenScreen MB166CR is not only powerful but also energy-efficient. Certified by ENERGY STAR, it consumes just 6 kWh/1000h in SDR (On mode), making it an eco-friendly choice for your digital workspace.
ASUS ZenScreen MB166CR - LED monitor - Full HD (1080p) - 16"
LED-backlit LCD monitor - 16"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1906388
Energy Class
Class B
Kickstand
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.179 mm
Brightness
250 cd/m²
Contrast Ratio
800:1
Response Time
5 ms (grey-to-grey)
Colour Support
262,000 colours
Input Connectors
USB
Screen Coating
Anti-glare
36.01 cm x 1.18 cm x 22.56 cm
780 g
Environmental Standards
ENERGY STAR Qualified
FCC Part 15 B, WEEE, EAC, TUV Rheinland Flicker Free Certification, TUV Rheinland Low Blue Light (Software Solution)
3-year warranty
Display Type
Energy Class
Class B
Diagonal Size
16"
Built-in Devices
Kickstand
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.179 mm
Brightness
250 cd/m²
Contrast Ratio
800:1
Colour Support
262,000 colours
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, ASUS Splendid Video Intelligence Technology, Trace Free Technology, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS EyeCare Technology, Blue Light Filter technology, Colour Temperature Selection, 360° rotatable, Anti-Flicker, tripod socket
36.01 cm x 1.18 cm x 22.56 cm - without stand
780 g
USB-C/DisplayPort Alt Mode
6 kWh/1000h
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Shipping Width
43.4 cm
Shipping Depth
7.6 cm
Shipping Height
29 cm
Shipping Weight
1.7 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 16in
Response Time: 5ms
Interfaces: USB
Brand: Asus
