Sleek and portable design
ASUS ZenScreen™ is ideal for life on the road. This sleek portable display is light weight and has a slim profile, so it fits easily in any travel bag and is ready for productivity, anytime and anywhere.
One cable is all you need
ZenScreen MB166CR uses a single USB Type-C* connection for both power and video transmission from your host device. This means you have less cables to work with, so you get a neater work area.
Designed with Versatility
A 360° detachable kickstand allow you to screw-in with ease on the rear tripod socket, enabling easy tilt adjustments in either portrait or landscape mode. With the 360° kickstand design you can even put it on a tabletop mount with ease.
Work efficiently in portrait and landscape modes
With ASUS DisplayWidget Center software2,ZenScreen MB166CR can automatically sense its orientation and switch the display between landscape and portrait modes while connected to your laptop. Landscape mode is ideal for presentations and spreadsheets, while Portrait mode gives you a perfect view of items such as documents, books or websites.
Extend your workspace
The FHD (1920 x 1080) IPS panel delivers stunning visuals and 178° viewing angles, ensuring you get superb color and contrast even when viewing the screen from off-center positions.
ASUS blue light filter
Exclusive ASUS Ultra-Low Blue Light technology protects you from potentially harmful blue light. It offers four filter settings that are easily accessed through the onscreen display menu via the hotkey.
Portable design
The ASUS ZenScreen MB166CR stands out with its portable form factor, making it an ideal companion for professionals on-the-go. Its lightweight design, complemented by a built-in kickstand, allows for easy setup and versatile viewing angles, ensuring productivity is never hampered, no matter the location. -
Exceptional visual quality
Experience stunning visual clarity with the 16-inch Full HD display, boasting a 178-degree viewing angle, 262,000 colors, and anti-glare coating. This monitor delivers vivid images and colors, making it perfect for both work and play. -
Eye comfort technology
Equipped with ASUS EyeCare Technology, the ZenScreen MB166CR minimizes eye strain during extended use. Features like Blue Light Filter technology and Anti-Flicker provide a more comfortable viewing experience, allowing you to work or enjoy your entertainment for longer periods without discomfort. -
Enhanced connectivity
With USB-C/DisplayPort interface, the monitor offers a seamless connection to a wide range of devices. This feature ensures easy Plug-and-Play setup, eliminating the hassle of multiple cables and adapters. -
Energy efficient
The ASUS ZenScreen MB166CR is not only powerful but also energy-efficient. Certified by ENERGY STAR, it consumes just 6 kWh/1000h in SDR (On mode), making it an eco-friendly choice for your digital workspace.
- ASUS ZenScreen MB166CR - LED monitor - Full HD (1080p) - 16"
- LED-backlit LCD monitor - 16"
- Energy Class
- Class B
- Kickstand
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.179 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 800:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 262,000 colours
- Input Connectors
- USB
- Screen Coating
- Anti-glare
- Dimensions (WxDxH) - without stand
- 36.01 cm x 1.18 cm x 22.56 cm
- 780 g
- Environmental Standards
- ENERGY STAR Qualified
- TUV Rheinland Flicker Free Certification, TUV Rheinland Low Blue Light (Software Solution), WEEE, EAC, FCC Part 15 B
- 3-year warranty
- Display Type
- Energy Class
- Class B
- Diagonal Size
- 16"
- Built-in Devices
- Kickstand
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.179 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 800:1
- Colour Support
- 262,000 colours
- Response Time
- Vertical Refresh Rate
- 60 Hz
- Horizontal Refresh Rate
- 24 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Tripod socket, 360° rotatable, Anti-Flicker, Blue Light Filter technology, ASUS EyeCare Technology, Trace Free Technology, ASUS Splendid Video Intelligence Technology, ASUS GamePlus, Colour Temperature Selection, ASUS QuickFit Virtual Scale, HDCP
- 36.01 cm x 1.18 cm x 22.56 cm - without stand
- 780 g
- USB-C/DisplayPort Alt Mode
- Power Consumption SDR (On mode)
- 6 kWh/1000h
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Included Software
- ASUS DisplayWidget Center
- Shipping Width
- 43.4 cm
- Shipping Depth
- 7.6 cm
- Shipping Height
- 29 cm
- Shipping Weight
- 1.7 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
