Asus ZenScreen MB165B Portable USB Monitor - 15.6 inch HD
Quicklinx: H3BDWS00 Mfr#: MB165B
Diagonal Size: 15.6in
Max Resolution: 1366 x 768
Response Time: 10ms
Interfaces: USB
24 In Stock
£129.22 ex VAT
£155.06 inc VAT
15.6-inch portable USB-powered monitor with a single USB 3.0 cable for power and video signal transmission
The slim and thin profile helps you get things done more efficiently when you’re on the go
User-friendly design with embedded tripod socket on the rear and foldable sleeve for versatility.
Can automatically sense its orientation and switch the monitor between landscape and portrait modes.
  • Sleek and portable design
    ASUS ZenScreen MB165B is ideal for life on the road. This sleek portable display is light and slim, so it fits easily in any travel bag and is ready for productivity, anytime and anywhere.
  • One cable is all you need
    ZenScreen MB165B portable USB-powered monitor needs just one USB cable for both its video signal and power, to be fully compatible with almost any laptop.
  • Work in comfort
    A ¼"-threaded hole at the rear of the monitor lets you to attach ZenScreen MB165B to a conventional tripod or table-mount easily.
ASUS ZenScreen MB165B - LED monitor - 15.6"
LED-backlit LCD monitor - 15.6"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/690552
Energy Class
Class B
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
WXGA 1366 x 768 at 60 Hz
Pixel Pitch
0.252 mm
Brightness
220 cd/m²
Contrast Ratio
500:1
Response Time
10 ms (tr + tf)
Colour Support
260,000 colours
Input Connectors
USB
Screen Coating
Anti-glare
Voltage
DC 5 V
36.014 cm x 1.18 cm x 22.564 cm
780 g
Display Type
Energy Class
Class B
Diagonal Size
15.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.252 mm
Brightness
220 cd/m²
Contrast Ratio
500:1
Colour Support
260,000 colours
Response Time
10 ms (tr + tf)
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, automatic orientation detection, landscape mode, portrait mode, narrow-bezel design, Display Widget, tripod socket
36.014 cm x 1.18 cm x 22.564 cm - without stand
780 g
USB 3.0
Input Voltage
DC 5 V
6 kWh/1000h
Power Consumption (Typical)
7 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Shipping Width
43.4 cm
Shipping Depth
7.6 cm
Shipping Height
29 cm
Shipping Weight
1.65 kg
Response Time: 10ms
Interfaces: USB
Brand: Asus
