Asus ZenScreen GO MB16AP 15.6" 1920x1080 5ms USB-C IPS LCD Monitor
Quicklinx: DTZHWS00 Mfr#: MB16AP
Diagonal Size: 16in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: USB-C
£254.80 ex VAT
£305.76 inc VAT
ASUS ZenScreen Go MB16AP is designed to keep you productive, wherever you are. It's a portable monitor with a hybrid-signal solution, which means that it only needs a single USB connector cable to be fully compatible with almost any laptop. With a super-slim 8 mm profile, and weighing just 850 g, ZenScreen Go MB16AP is also light 15.6-inch companion display.
To enjoy the convenience of a truly portable device with 7,800 mAh battery built-in that supports up to 4 hrs battery life. Support QC3.0 fast battery charging, doubled charging speed in comparison to general adapters. ZenScreen Go MB16AP works with laptops, and mobile devices. To project app or content from your mobile device, simply download and use the DisplayLink app. To check battery status by simply press the hotkey.
ZenScreen Go MB16AP only requires a single USB connection for both power and video transmission from your host device. It features an innovative hybrid-signal solution with native support for USB Type-C (USB-C) connections, and uses an installed driver to support USB Type-A connectors for full compatibility. The reversible, any-way-up USB-C design enables quick, hassle-free connection to any device.
  • Extend your vision, free your world
  • Built to be on the go
  • Hybrid-signal solution: USB Type-A and Type-C support
  • Slim and stylish ultraportable design
    ZenScreen MB16AP is ideal for use as a secondary monitor for dual-monitor presentations, and its versatility helps you get things done more efficiently when you're on the go. It barely tips the scales at a lightweight 850 g, and with its ultra-slim 8 mm profile it fits easily in any travel bag.
  • Wide viewing angles
    ZenScreen Go MB16AP features a Full HD panel that delivers stunning 1920 x 1080 resolution visuals with outstanding color reproduction. It uses IPS technology to give you more flexibility when extending your screen, so you still get superb color and contrast - even from extreme viewing positions.
ASUS ZenScreen GO MB16AP - LCD monitor - Full HD (1080p) - 16"
LCD monitor - 16"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/419761
Energy Class
Class C
Power Consumption (On mode)
7 W
Lithium-polymer battery (7800 mAh)
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.179 mm
Brightness
220 cd/m²
Contrast Ratio
800:1
Colour Support
262,000 colours
Input Connectors
USB-C
Dark grey
35.97 cm x 0.8 cm x 22.64 cm
850 g
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, J-MOSS, UkrSEPRO, RCM, BIS, CU-EAC, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
3-year warranty
Display Type
LCD monitor / TFT active matrix
Energy Class
Class C
Diagonal Size
16"
Viewable Size
16"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.179 mm
Brightness
220 cd/m²
Contrast Ratio
800:1
Colour Support
262,000 colours
Glare, ASUS Splendid Video Preset Mode, ASUS GamePlus, Slim Design, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, auto-rotation, USB 3.0 Quick Charge, Wide Viewing Angle, Super Narrow Bezel Design
Dark grey
850 g
USB-C
ZenScreen pen, ASUS Smart Case
1 x USB-C cable , 1 x USB-C to USB-A adapter
7 W
7 kWh/1000h
Power Consumption (Typical)
9 watt
Power Consumption Stand by
0.5 watt
Power Consumption (Off Mode)
0.3 watt
Microsoft Windows 7 / 8.1 / 10
Shipping Width
43.4 cm
Shipping Depth
7.6 cm
Shipping Height
31 cm
Shipping Weight
3.1 kg
Limited warranty - 3 years
5 °C
35 °C
20 - 90%
Diagonal Size: 16in
Response Time: 5ms
Speakers: None
Interfaces: USB-C
Brand: Asus
