                Compact designZenBook 14 heralds an era of portable design, with an ultra-compact, ultra-light chassis. Featuring the 4-sided NanoEdge display, the ZenBook 14 is extremely sleek.
                Unbounded beautyDesigned to give you more screen area in less physical space, the frameless four-sided NanoEdge design of ZenBook 14 is simply breathtaking: it makes any visuals more immersive, with less distraction for your eyes.
                Spectacular visualsCreativity demands a great screen, so ZenBook 14 has a crisp, clear, high-resolution display that makes any visuals look their best, with wide viewing angles and vivid, accurate colors.
                Designed with you in mindWith any ZenBook, your comfort is a high priority ZenBook 14 goes the extra mile with its exclusive hinge, an engineering masterpiece designed to automatically tilt the keyboard to a comfortable typing position. But that's not all: the carefully calculated tilt improves cooling and audio performance, too.
                Mobility without boundsAs a mobile professional, you need to stay connected. ZenBook 14 is equipped with Wi-Fi, so you can enjoy fast downloads and smooth streaming with greater range and more stable network connections.
                All-day battery for non-stop lifestylesZenBook 14 is powered by a high-capacity battery that won't let you down, however long and demanding your working day is. Extended journeys or day-long meetings are no problem for ZenBook 14, even when power outlets are in short supply.
- ASUS ZenBook 14 UX433FA-A5046T - 14" - Intel Core i5 - 8265U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Windows 10 Home
- Processor
- Intel Core i5 (8th Gen) - 8265U / 1.6 GHz, up to 3.9 GHz / 6 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD - NVMe
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- NumberPad
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Battery
- 3-cell
- Royal blue
- 31.9 cm x 19.9 cm x 1.59 cm
- 1.19 kg
- Product Type
- Notebook
- Operating System
- Windows 10 Home
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Ultra Slim Design, ASUS Splendid Video Intelligence Technology, anti-glare, 178° horizontal and vertical viewing angle, NanoEdge display
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Camera Features
- IR/RGB camera
- Sound
- Harman/kardon stereo speakers, array microphone
Input
- Keyboard, NumberPad
Communications
- Wireless
- Technology
- 3-cell lithium polymer
- Capacity
- 50 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , USB-C 3.1 Gen 2 , USB 3.1 Gen 1 , HDMI , USB 2.0
- Memory Card Reader
- Yes (microSD)
- Royal blue
- Included Accessories
- Power adapter
- 1.19 kg
Sustainability Information
- TCO Certified
