ASUS ZenBook Slim UX391 with up to Intel® Core™ i7 processor
Introducing 8th Gen Intel® Core™ i7-8550U platform. Your computers performance optimised for you.
Slim. Sublime. Supreme. ZenBook S is all these, yet so much more. Its elegant sophistication will touch your heart and enhance your prestige, wherever you use it. Its effortless portability, powerful performance and no-compromise connectivity let you get things done without fuss, without drama. And its innovative design incorporating our unique ErgoLift hinge not only sets you apart from the crowd, but lets you work in supreme comfort too. ZenBook S: it's the laptop you deserve.
Thin and light
Seriously portable - As a seasoned traveler, you'll appreciate the way ZenBook S slips effortlessly into your bag, with its svelte profile taking up the bare minimum of space and adding hardly any weight. Less bothersome bulk, more room for the really important stuff.
Designed for ultimate comfort
With any ZenBook, your comfort is one of our top priorities, ZenBook S goes the extra mile with its exclusive ErgoLift hinge, an engineering masterpiece designed to automatically tilt the keyboard to the most comfortable typing position. But that's not all: the carefully calculated tilt improves cooling and audio performance, too.
Performance
ZenBook S is built to get things done as quickly and efficiently as possible, with no fuss or drama. The latest Intel® Core™ processors mean you'll enjoy smooth and responsive performance whatever you're doing, and the state-of-the-art components are all specially selected to ensure you'll spend less time waiting and more time enjoying.
Seriously portable
As a seasoned traveler, you'll appreciate the way ZenBook S slips effortlessly into your bag, with its svelte profile taking up the bare minimum of space and adding hardly any weight. Less bothersome bulk, more room for the really important stuff. -
With any ZenBook, your comfort is one of ASUS's top priorities. ZenBook S goes the extra mile with its exclusive ErgoLift hinge, an engineering masterpiece designed to automatically tilt the keyboard to the most comfortable typing position. But that's not all: the carefully calculated tilt improves cooling and audio performance, too. -
Vision of beauty
A laptop as beautiful as ZenBook S deserves equally beautiful visuals, so ASUS has fitted it with an ultra-high-definition NanoEdge display with lifelike colors and detail that will take your breath away. It has also reduced the bezel width even further, to give you an even more immersive view while keeping ZenBook S amazingly compact. -
Evolved cooling
For maximum performance, heat needs to be removed as quickly as possible. ZenBook S uses an uprated cooling system incorporating modern components. A fan housing design with improved airflow gently expels warm air from the interior via hidden vents in the hinge, for efficient, serenely quiet cooling even under full load. -
Connect fast, connect anywhere
When you're on the go, no-compromise connectivity is essential. ZenBook S delivers the ultimate speed of Thunderbolt 3 in two of its three USB-C ports, and all ports support fast charging, data transfers and display connectivity. -
Immersive Harman Kardon audio
A special smart amplifier ensures maximum volume with minimum distortion for powerful, clear sound. Once you've tried it, ASUS thinks you'll agree that ZenBook S delivers the most incredible sound you've ever heard on an portable laptop. -
More comfortable, by design
All too often, laptop keyboards seem to be an afterthought. But not on ZenBook S: its ergonomic keyboard is designed from the start with comfort in mind. It has widely spaced, long-travel keys that feel more like a desktop, and the tops of the keys are gently dished to aid accurate typing. The gentle backlight lets you work in any lighting conditions, while remaining easy on the eyes.
- ASUS ZenBook S UX391UA ET013R - 13.3" - Core i7 8550U - 16 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro
- Processor
- Intel Core i7 (8th Gen) 8550U / 1.8 GHz (4 GHz) / 8 MB Cache
- Memory
- 16 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 13.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 4-cell - up to 13.5 hours
- Security
- Fingerprint reader
- Deep dive blue
- 31.1 cm x 21.3 cm x 1.29 cm
- 1.05 kg
- Limited warranty - 1 year - on-site
- Product Type
- Notebook
- Operating System
- Windows 10 Pro
Processor / Chipset
- CPU
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 16 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
Storage
- Main Storage
- 256 GB SSD M.2 SATA 6Gb/s
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Colour Gamut
- 100% sRGB
- Anti-glare, WideView, 178° horizontal and vertical viewing angle
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Sound
- Harman/kardon stereo speakers, array microphone
- Audio Features
- ASUS SonicMaster
Input
- Keyboard, touchpad
- Windows Hello
Communications
- Wireless
- Technology
- 4-cell lithium polymer
- Capacity
- 50 Wh
- Run Time
- Up to 13.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 20 V
Connections & Expansion
- Headphone/microphone combo jack , USB-C 3.1 Gen 1 (Power Delivery/data/video) , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3) (Power Delivery/data/video)
- Deep dive blue
- Security
- Included Accessories
- USB-C power adapter
- 1.05 kg
