The most compact design ever
ZenBook 14 heralds a new era of ultraportable design, with an ultracompact, ultralight chassis. Featuring the four-sided NanoEdge display, ZenBook 14 is one of the world's smallest 14-inch laptop and is 13% smaller than the previous generation ZenBook 14 (UX430) - so you can explore your creative vision anywhere!
Unbounded beauty
Designed to give you more screen area in less physical space, the NanoEdge design has slimmer bezels on all four sides to make any visuals more immersive, with less distraction for your eyes. It also features wide-view technology for clear images even when viewed from extreme angles. ZenBook 14 has a crisp, clear, high-resolution display that makes any visuals look their best, with wide viewing angles and vivid, accurate colors.
Designed with you in mind
With any ZenBook, your comfort is one of our top priorities. ZenBook 14 goes the extra mile with its exclusive ErgoLift hinge, an engineering masterpiece designed to automatically tilt the keyboard to the most comfortable typing position. But that's not all: the carefully calculated tilt improves cooling and audio performance, too.
Compact design
ZenBook 14 heralds an era of portable design, with an ultra-compact, ultra-light chassis. Featuring the 4-sided NanoEdge display, the ZenBook 14 is extremely sleek. -
Unbounded beauty
Designed to give you more screen area in less physical space, the frameless four-sided NanoEdge design of ZenBook 14 is simply breathtaking: it makes any visuals more immersive, with less distraction for your eyes. -
Spectacular visuals
Creativity demands a great screen, so ZenBook 14 has a crisp, clear, high-resolution display that makes any visuals look their best, with wide viewing angles and vivid, accurate colors. -
With any ZenBook, your comfort is a high priority ZenBook 14 goes the extra mile with its exclusive hinge, an engineering masterpiece designed to automatically tilt the keyboard to a comfortable typing position. But that's not all: the carefully calculated tilt improves cooling and audio performance, too. -
Mobility without bounds
As a mobile professional, you need to stay connected. ZenBook 14 is equipped with Wi-Fi, so you can enjoy fast downloads and smooth streaming with greater range and more stable network connections. -
All-day battery for non-stop lifestyles
ZenBook 14 is powered by a high-capacity battery that won't let you down, however long and demanding your working day is. Extended journeys or day-long meetings are no problem for ZenBook 14, even when power outlets are in short supply.
- ASUS ZenBook 14 UX434FAC-AI246T - 14" - Intel Core i5 10210U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Windows 10 Home
- Processor
- Intel Core i5 (10th Gen) 10210U / 1.6 GHz (4.2 GHz) / 6 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 14" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics
- Input Device
- ScreenPad 2.0
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac/ax
- Battery
- 3-cell
- Security
- Trusted Platform Module (TPM) Security Chip
- Royal blue
- 31.9 cm x 19.9 cm x 1.69 cm
- 1.26 kg
- Limited warranty - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Home
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.2 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 2133 MHz
Storage
- Main Storage
- 256 GB SSD M.2 PCIe
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Colour Gamut
- 72% NTSC
- ASUS Splendid Video Intelligence Technology, glare, 178° horizontal and vertical viewing angle, NanoEdge display
Audio & Video
- Graphics Processor
- Camera
- Camera Features
- IR camera
- Sound
- Harman/kardon stereo speakers, microphone
- Audio Features
- Output: ASUS Bang & Olufsen ICEpower, Smart Amplification technology
Input
- Keyboard, ScreenPad 2.0
- Chiclet keyboard
Communications
- Wireless
- Technology
- 3-cell lithium polymer
- Capacity
- 50 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 3.42 A
Connections & Expansion
- Headphone/microphone combo jack , USB-C 3.1 Gen 2 , USB 3.1 Gen 2 , HDMI , USB 2.0
- Memory Card Reader
- Yes (microSD)
- Royal blue
- Security
- System password, ErgoLift
- Theft/Intrusion Protection
- Cable lock
- Included Accessories
- Power adapter
- 1.26 kg
