Combining versatility with the ultimate mobility, ZenBook Flip 13 features a frameless NanoEdge design. Its 13-inch display has ultra-narrow bezels on all four sides, giving a 90% screen-to-body ratio that allows a much more compact chassis design. With its 360° flippable ErgoLift hinge, powerful processor, active-stylus support and innovative NumberPad dual-function touchpad, ZenBook Flip 13 is versatile, powerful and supremely portable.
Unbounded beauty
The frameless NanoEdge design of ZenBook Flip 13 brings a whole new dimension to your viewing experience. The ultra-slim bezels give you expansive and immersive visuals that are distraction-free, making work or play a true pleasure. -
Unique 360° ErgoLift hinge
The 360° ErgoLift hinge on ZenBook Flip 13 has a silky-smooth, stepless action that holds the display securely at any angle. This innovative hinge also lifts and tilts the keyboard into a comfortable typing position when the display is opened beyond 135°. The ErgoLift hinge is torture-tested to ensure maximum reliability for total peace of mind. -
Incredible performance
Performance is crucial part of the ZenBook experience, and the versatile ZenBook Flip 13 doesn't disappoint. Every component has been selected to deliver great performance in a thin and light design, making it an ultra-portable powerhouse that's faster than ever before. You'll never be kept waiting by ZenBook Flip 13, however demanding the task. -
NumberPad: reinventing the touchpad
ZenBook Flip 13 introduces the amazing NumberPad, an innovative solution to the lack of space for a numeric keypad on small laptops. Just long-press the NumberPad icon on the touchpad to turn the glass-covered touchpad into an LED-illuminated keypad with a familiar layout for easy data entry. -
Convenient connectivity
Whether you're in the office or on the road, you need to be able to connect to all your devices and peripherals with the minimum of fuss. ZenBook Flip 13 includes a USB Type-C (USB-C) port with its reversible, any-way-up connector design. -
Work longer, charge faster
ZenBook Flip 13 uses a high-capacity battery that won't let you down, however long and demanding your working day is. And its fast-charge technology lets you recharge up to 60% capacity in as little as 49 minutes, so you can be up and running quicker than ever. -
Harman Kardon audio
To give ZenBook Flip 13 unsurpassed audio capabilities, the ASUS Golden Ear team cooperated with audio specialists Harman Kardon to produce the next generation of ASUS SonicMaster Premium audio technology. The results are astonishing. ZenBook Flip 13 has two high-quality stereo speakers and surround-sound effects that envelop you with cinema-quality audio. A special smart amplifier ensures maximum volume with minimum distortion for powerful, clear sound.
- ASUS ZenBook Flip 13 EL168R - 13.3" - Core i5 8265U - 8 GB RAM - 512 GB SSD
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz)
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 512 GB SSD
- Optical Drive
- No optical drive
- Display
- 13.3" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- NumberPad
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11ac, Bluetooth 5.0
- Battery
- 3-cell
- Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip
- Royal blue & concentric circle (LCD cover)
- 30.5 cm x 19.6 cm x 1.69 cm
- 1.3 kg
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 2133 MHz
Storage
- Main Storage
- 512 GB SSD - (M.2) SATA 6Gb/s
Display
- 13.3" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Glare, 72% NTSC colour gamut, 100% sRGB colour gamut, 178° horizontal and vertical viewing angle, NanoEdge display
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Camera Features
- IR/RGB camera
- Sound
- Harman/kardon stereo speakers, dual array microphone
- Audio Features
- ASUS SonicMaster Premium
Input
- Keyboard, NumberPad
Communications
- Wireless
- Technology
- 3-cell lithium polymer
- Capacity
- 50 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V, 3.42 A
Connections & Expansion
- Headphone/microphone combo jack , USB 2.0 , 2 x USB-C 3.1 Gen 1 , HDMI
- Security
- System password
- Included Accessories
- Stylus, power adapter, protective sleeve
- 1.3 kg
